drop in outboard on stiletto
  • Serpents811
    • Oct 2011
    • 381
    ok im new to stiletto and im already looking into some mods for it how ever outboard leg looks is killing me and im looking to change it with something that could be mounted to the original mount?
  • Serpents811
    • Oct 2011
    • 381
    CANT BELIEVE NO ONE HASNT BEEN ABLE TO ANSWER MY QUESTION
    • Darin Jordan
      • 8335
      Sorry, but I spent almost a year developing the Stiletto with Pro Boat, and especially took a lot of time to get that lower unit to function like a race-unit, but look like a scale unit... It's a KILLER unit, and functions great, especially if you take the time to blue-print it, as described in my race prep thread, here on this site. I COULD be a little offended by your post comments...
      However, being that I have broad shoulders and don't easily take offense... I will tell you that the bolt pattern on the transom should match up almost exactly with an OS Lower... I'm not sure if the stub height will be able to be correct with the stock OS adjustment range, but I think it should be relatively close.
      I think that a Lawless or other race style lower can be fitted if you use a Dubro 3.5 mount also. I believe the pattern should match up.
      You'll save a bit of weight with different lower. The stock one weighs around 13oz, if I recall. I think my Lawless weighs about 8oz...
      Have FUN!
      Darin E. Jordan - Renton, WA
      • Serpents811
        • Oct 2011
        • 381
        Have FUN!
        By all mean no disrespect on the design and the time that took the develope this boat and the components that make this boat complete however I'm more like a looks kind of guy and also performance but I just don't want my stiletto to look just like another stiletto and still perform as well , however my first time on the water with it everything still stock and the shaft assembly broke on it thumps down on that one so on that note thanks for the reply Darin and any Other tips will be appreciated
        • CHIEFY_44
          • Nov 2010
          • 254
          As Darin said read his race prep thread do as he says in there and you won't have any trouble apart from regular wear and tear I have one done all the race prep and the boat flies and in 12 months I have broke 2 flex shafts and that's it, as to the outdrive part of the outboard just change that for a hyperformance one fits in exactly and works very well. I do recommend you read darins thread well worth it.
          Stephen
          Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
          • Serpents811
            • Oct 2011
            • 381
            ok so conquest has been acomplished here is a pix
            • jamespl
              • 742
              I don't think it looks as good as the stock one if I'm honest. Does it perform any better?
              http://inlinethumb55.webshots.com/32...600x600Q85.jpg
              http://inlinethumb04.webshots.com/45...600x600Q85.jpg
              • Serpents811
                • Oct 2011
                • 381
                it actually performs better than the stock one plus you dont have to make all the mods like the stock one and is lighter
                • rhengst22
                  • Aug 2012
                  • 72
                  Hey serpent can you please inform me on what outboard did you put on your stiletto and are there any problems with it? Anymore broken flex cable? Also I am curious why did the stock stiletto have the motor cover and yours does not, will water mess up the motor if the boat flips?
                  • Serpents811
                    • Oct 2011
                    • 381
                    The was a OS outboard unit , there is really no need for the motor cover as brushless motors could go underwater with damaging them just spray some corrosion x and the way you go , performance wise OS outboard units are much better than stock just my opinion but then again I wouldn't waste my time putting it on stilleto on a different hull yes
                    • rhengst22
                      • Aug 2012
                      • 72
                      Where did you get it? What flex cable did you use and where did you get it? And wait so why not put it on a stiletto hull? You did.
                      • Serpents811
                        • Oct 2011
                        • 381
                        I used the stock flex cable that came with the OS outboard , at the time I didn't know much about tunnel boats and as i learned more about them I came to the conclusion that the stilleto is just and meant to be just a rtr and not a racing boat then again this is just my opinion , now if you want a good handling tunnel to start heat racing aquacraft vs1 is good start but needs to be converted to fe as it is a nitro hull
                        • Serpents811
                          • Oct 2011
                          • 381
                          You can find the OS OUTBOARD HERE ON OSE , it is a bolt on deal with no mods needed besides modding your cowl to fit the motor
                          • Serpents811
                            • Oct 2011
                            • 381
                            Here is a link to a vs1fe video I had on race trim running with modded nitro tunnels , the boat red and white
                            • Serpents811
                              • Oct 2011
                              • 381
