interference?
  • mountains
    • Aug 2011
    • 34
    interference?
    tok boat out yesterday switched on its bleeping constantly and the servo is constantly jittering its like interference,the batts are fully charged the tranny batts are fully charged the boat has not been run for 2 weeks any ideas.
  • jamespl
    • 742
    Mine does it. Turn the steering fully left or right and let go so it returns to centre then it should stop. It will do it every time you plug the batts in tho. I wouldn't worry about it.
    http://inlinethumb55.webshots.com/32...600x600Q85.jpg
    http://inlinethumb04.webshots.com/45...600x600Q85.jpg
    • Darin Jordan
      • 8335
      There is drag and load on the steering pull-pull cables, and the sound you hear is the servo constantly trying to center itself. Mine does it too. Especially prevalent with digital servos, which will "insist" on finding the center...
      Darin E. Jordan - Renton, WA
        • 8011
        Loosening the steering cables a bit will help to reduce the noise. Too loose will add slop to the steering, but mine was way too tight at first.
        • Darin Jordan
          • 8335
          Yup... I think it may come from the tension pulling the servo head back as well. The cables don't need to be super tight... Just don't need any slop.
          Thanks, Jay. I had forgotten about that part.
          • mountains
            • Aug 2011
            • 34
            thanks guys good advice, im a bit concerned as this is the first time its done this since i got it started suddenly
            • mountains
              • Aug 2011
              • 34
              further to my previous post took the boat out today it was awful the servo was jittering badlly so much so the boat was steering both ways but on its return it wasnt returning smoothly it was also not centering. i disconnected the steering wheel and the servo was still jittering badly another boater sggested it could be moisture in the servo and suggested i put it in a warm place for a couple of hours, so im trying it to see if theres any improvement. ill let you know
              • mountains
                • Aug 2011
                • 34
                interference
                another update left the servo in a warm place overnight tried it this morning no change I contacted horizon Hobby they seem to think its a faulty servo so its gone back to be tested.
                • mountains
                  • Aug 2011
                  • 34
                  interference
                  update, i sent the servo back to model shop they said it had gone back to horizon 2 weeks later they said they had not got it, model shop said they sent it. they have offered me a Hi tec servo as it looks like the original is lost in the post so i dont know wethe the original is faulty or not, Im not very happy so am considering sending the boat back
