pro boat stiletto l40 x 57 prop opinions
  • Piranhafreak
    • Jul 2011
    • 25
    What does everyonething about running the grimracer l40 x 57 prop on a stock stiletto ? i tried the 40 x 52 and seemed to make no difference im hoping this will change that i will then likely change the esc too
  • dana
    Banned
    • Mar 2010
    • 3573
    L40/57 won't work well. It's a lifter prop for hydros or riggers
    • Piranhafreak
      • Jul 2011
      • 25
      what would be the ideal prop i would have thought the tunnel hull would be close to a hydro
      • Driggs
        • Mar 2010
        • 69
        I've used a 40x57L , and a 42x55 2 blade, and a x440 3 blade,, for me the x440 3 blade is the best, I run 4cell and 5 cell, but I found that the 42x55 2blade was the best for speed and seems to be safe for the electrics and heat buildup when running on 4cell, also run on low timeing , there is a big difference in speed from stock with the 42x55, I've tested this while raceing other stilettos
        • dana
          Banned
          • Mar 2010
          • 3573
          a tunnel and a hydro are so completely different. if anything a tunnel is more like a catamaran, but not really. i was also gonna suggest the 42x55 and the x440/3.
          • Piranhafreak
            • Jul 2011
            • 25
            WELL I HAD THE3 PROP SO i tried it it was alot faster but couldnt get up and going i had to give it a push or a full throttle punch and it was nasty but had a very hard time getting up and going not a good choice
            • Piranhafreak
              • Jul 2011
              • 25
              so i pulled everything out of the stiletto and installed it into a shockwave hehe lets see how that goes i now plan to build the stiletto up i just need to figure out what the biggest motor i can fit in that outboard is
              • CHIEFY_44
                • Nov 2010
                • 254
                i run a p220 on mine everything standard bar for the prop runs great too
                Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
