help on my stiletto
  • antonio68
    • Jun 2011
    • 3
    help on my stiletto
    Hello guys
    I'm Italian and I use google translated because I do not know English.
    I hope to be understandable.
    I would like to install on my stiletto engine 1515 2200KV 1Y
    It is possible, given that the 1515 has 3 screws??
    Okay a control (ESC) 180A?
    Thank you for this wonderful forum
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    Its ok to use 3 screws if the mounting plate will take the spacing of the motor screws.
    180 ESC is also ok.
    Post some pictures here of how it is done when you finish...
    Canada
    • antonio68
      • Jun 2011
      • 3
      Unfortunately, in Italy for the boats is not nothing.
      I have to order the material on the OSE, and it takes a long time.
      but thanks to your forum I keep up to date.
      I made ​​all the changes I have suggested you on the forum.
      I have not done grinding because I'm afraid of damaging the hull.
      Ascolta
      Trascrizione fonetica
      Dizionario
      • GP73
        • 544
        Antonio se ti serve aiuto mandami un messaggio privato, ho anch'io lo stesso scafo, non c'e' spazio per un regolatore T180, e' troppo largo. A meno che non allarghi il vano batterie. :)
        Ti consiglio un Leopard 2000Kv (oppure un UL-1 2030Kv) e un regolatore Swordfish 120a.
        Sorry guys, just helping Antonio.
        • GP73
          • 544
          Just for reference, here is a pic of a T180 in the Stiletto, it's not going to fit unless you modify the hull.
          • CHIEFY_44
            • Nov 2010
            • 254
            i think you can jut squeeze it in if you change the water inlets/outlets to 90deg ones
            Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
            • antonio68
              • Jun 2011
              • 3
              cover carbonio
              • GP73
                • 544
                You're right! I didn't think about changing the water nipples.
                Good to know.
                • CHIEFY_44
                  • Nov 2010
                  • 254
                  becareful changing them i have heard people say they have snapped them off properchopper told me its best to use some heat on them b4 you try to remove them
                  • electric
                    • May 2008
                    • 1744
                    Originally posted by antonio68
                    cover carbonio
                    Nice look!! Much easier to tape down as well.
                    • LiPo Power
                      • May 2009
                      • 3186
                      That is right! Why T-180 if T-120 fits with no problem....
                      I have UL-1 motor on mine and it goes sweet!!!
                      Canada
