Picked this up used from Ron. I digged the decals he put on. Really look nice on this hull. I just finished everything up tonight. Here's the setup.
Motor: CC1512 1.5y 1800kv
Esc: Seaking 120
Servo: stock
Rx: Mr3000
Batts: 4s1p either 5000mah 40c-50c or 6000mah 25-50c
Prop: I think I will try a m445 to start
I never ran a tunnel hull before so kinda nervous on this one. I didn't know exactly where to set the outboard depth and angle so I set a neutral angle and set the prop shaft in the middle of the sponsons to start. If that's not good maybe a tunnel guy can chime in on that one. I modded the outboard cover so the 1512 could fit in I also epoxyed in a terminal block in the hull. Motor plugs in on one side motor on the other side looks kinda cool IMO.
I seen after I took the photo the cooling line was tight on the bottom of the esc so it's got extra room now and I swang the outboard full right and full left and everything looked good and wasn't tight.
Esc: Seaking 120
Servo: stock
Rx: Mr3000
, best bit of advice is look at darins set up and u wont be far wrong.
