took my new stiletto out yesterday and gave it the first run ,ran perfect for 5 minutes then dead in the water no power any where ,looks like the esc is not working ,has enyone else had this problem .currently trying to get a hold of proboat to see what i can do .
new stiletto dead in the water
not fast at all , combo of the pond being to small and knowing that the boat is fast so i was just feeling it out maybe 1/2 to3/4 on the trigger and yes i would have to say that it was a pleasure to deal with the rep at horizon hobby we ended up talking boats for quite some time after we solved the esc issue.now that the new part is in the mail that will give me time to get my new aquacraft superior in the water as it just arived today and looks like another fast boat .that makes 10 boats in the fleet, should be a good summer.super vee 21 brushless
Rio EP brushlessComment
not fast at all , combo of the pond being to small and knowing that the boat is fast so i was just feeling it out maybe 1/2 to3/4 on the trigger and yes i would have to say that it was a pleasure to deal with the rep at horizon hobby we ended up talking boats for quite some time after we solved the esc issue.now that the new part is in the mail that will give me time to get my new aquacraft superior in the water as it just arived today and looks like another fast boat .that makes 10 boats in the fleet, should be a good summer.Comment
This statement seems odd...Please explain a little more about why an ESC wouldn't be able to run at half throttle or more without burning up...I run R/C Cars and the ESC's dont have that problem at all.....Just wondering what would be different?Spektrum Radios
Proboat "Impulse" 31 Deep-V
Proboat "Mystic" (On the list!)Comment
you can't use all the same practices from cars/planes/heli's into boating. Different factors. Stick a eagletree to this setup and I think you will be shocked to the amount of amp draw you really have!
* In boating long wide open throttle runs are best, also timing your runs will help. I normally run between 3-4 minutes timed on 4500mah or greater and 30c or greater batts. I try to never hit the lvc...Comment
Cars are completely different, boats draw A LOT more amps then cars due. The esc is like a switch either on or off, when you go half throttle or 3/4 throttle the esc fets start cycling on/off to meet the requested demand that on/off cycling creates a whole lot of excess heat, add that heat to the amp load =you can't use all the same practices from cars/planes/heli's into boating. Different factors. Stick a eagletree to this setup and I think you will be shocked to the amount of amp draw you really have!
* In boating long wide open throttle runs are best, also timing your runs will help. I normally run between 3-4 minutes timed on 4500mah or greater and 30c or greater batts. I try to never hit the lvc...Spektrum Radios
I have similar batteries 6000mah 25c-50c batts. I still time under 5 minutes. 5min in FE boating is long time. The batts maybe able to supply the needed amps for that period of time it's just a matter if the system (esc & motor) will handle that amount of time. Best thing I could suggest would be to run for 3 minutes and bring the boat in, check the temps real fast, if all is ok run it for another min or so. I don't risk my setup for a few extra minutes, that's just me.Comment
Slow run will NOT create proper cooling circulation.
When you get your new ESC make sure to hummer it more often or get the water pomp to cool your motor and ESC properlyDJI Drone Advanced Pilot
CanadaComment
