will /can the stilletto be competitive against nitro opc's 3.5 thats all thats around here to race, I figure if I can win a few races it might open up some eyes. I am sure they will let me run with them. just wondering .. joe
fe verses nitro
You may have to change the OB to an O.S. or something like it"A quick temper will make a fool of you soon enough."
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Bruce Lee. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -
what kind of speeds do the nitro boats do? with a little work this boat could do 45 or so.....maybe more but heat is a problem sometimes,,,,,MY RETIREMENT PLAN?????.....POWERBALL
Not sure on the speeds, but they are pretty fast."A quick temper will make a fool of you soon enough."
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Bruce Lee. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Comment
Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
Sorry Darin, I was not thinking "spec""A quick temper will make a fool of you soon enough."
The biggest advantage with an FE OB versus a nitro OB seems to be reliability. Over a multi-heat race the FE boat will likely compile more points than most of the nitro boats, even if it isn't as fast. But then some ARE as fast or a bit faster than the nitro tunnels. You just don't have to be faster to do well.
No worries... But either way, you shouldn't need to replace the OB, even to upgrade to a hotter motor. It'll handle it!
I'd do the performance mods mentioned in my Stiletto race prep thread. Should be nearly bullet-proof then. Biggest improvements would be to get a Hyperformance Bullet-Drive stubshaft and flexcable from Steven, and then properly fit the flex. After that, I see no reason why this OB can't be a race OB. You'll be paying a slight weight penalty, but not enough to justify a completely new setup.
All just in my opinion, of course...Darin E. Jordan - Renton, WA
Have you posted a pic of the bottom of your boat after the block sanding?"A quick temper will make a fool of you soon enough."
I thought I did. I'm a little behind on posting pics. I have some that show some of the prepping I've done, but have been busy with other things and haven't posted them yet.
Our main race season ends this weekend. After that, it will be mostly building time, so hopefully I can get caught up.Darin E. Jordan - Renton, WA
I'm talking about just replacing the stub shaft and flex cable... Mostly the stub. I like the aftermarket flex cables because the flat section is shorter, allowing the cable to arch more coming into the squaredrives. The Hyperformance stub is simply awesome and will last forever.Darin E. Jordan - Renton, WA
