Yes
Stiletto First Run w/New Boat
I also sealed around all of the water lines on mine, and around the wires. They pass through double-hull sections, so if any water gets past them, it can get down inside the hull.
Mine stays dry inside now.Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @Comment
Oh well, I knew this was going to happen... I chipped the gelcoat on the tip of the left sponson.
Don't ask me how since I have NO idea, I didn't see the missing gelcoat when I got her out of the car, so I must have hit something at home.
I'll try to get some supply at a local marine supply store. Any suggestions for a gelcoat repair kit? Should I use just gelcoat paste? Or epoxy? What about color matching?
It's a small chip, about the size of a small bean.
Thanks.Comment
man, I wish this would bind to a DX6i.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
I've never heard of one being preset to the logarithm mode. In fact, I've never even used one in that mode. I can ask, but I'm certain it does NOT come pre-programmed in that mode. Should be linear.
I have noticed that the "steps" in the ESC are pretty large. Running at full throttle, then lightly backing off, results in a pretty decent drop in throttle. Typical RTR throttle curve.Darin E. Jordan - Renton, WA
ALD... I really don't think that "beginner mode" is necessary for most people... in fact, on a tunnel, it may make it tough to balance the boat in the turns.
For the Stiletto, on the stock setup, I'd set the programming like this:
Battery Type: Lipo (assuming you are using Lipos)
Cutoff Voltage: LOW
Cutoff Type: Slow Down
Brake: OFF
Timing: LOW
Throttle Curve: LINEAR
Try that and get used to running the boat. If your temps are good and all is happy, then you can try the HIGH timing setting, which MIGHT (jury is still out with this boat) give you a little more zip...Darin E. Jordan - Renton, WA
first run
had first run on smooth water.....ran great but no 40 mph for sure..... still needs motor angle and hight adjusted to a better position.....darin can u take a pic of your motor hight mounting screws pls and the angle of the motor? that would really help me......funny thing happened to me as i flipped the boat powering it up across its own wake......current going out....its a swim or just wait for it situation....i pull the throttle and the prop is touching the water and i power it in(about 20yds upside down...now i know it didnt do the motor any good underwater but will oil the barrings etc and hopefully it will be fine as i ran it for 5 mins after that and ran fine.....MY RETIREMENT PLAN?????.....POWERBALL
74 vintage kirby clasic hydro, pursuit mono, mg, 47'' mono, popeye hydro...Comment
will these take full speed turns?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
