new boat broken
  • gbrown2210
    • Jun 2013
    • 18
    new boat broken
    Okay I was running a lot of full throttle and the boat stop. Got it out of the pond unplugged then turned it back on off in the water as soon as I put a load on it nothing. Is this a bad ESC. Boats a day old.
  • Chilli
    • Jan 2008
    • 3070
    Possibly ran the batteries low and the low voltage cutoff was kicking in when the batteries were put under a load. How long did you run her for? Try charging up the packs and running her again.
    Mike Chirillo
    www.capitolrcmodelboats.com
    • gbrown2210
      • Jun 2013
      • 18
      Five min roughly. Its programmed to slow down that never happened?
      • G-UNIT
        • 949
        bad solder connections may be.
        • gbrown2210
          • Jun 2013
          • 18
          • gbrown2210
            • Jun 2013
            • 18
            Sorry for the double reply....I mean it could be, that wouldn't explain that unplugging and re plugging. I guess it could
            • Heaving Earth
              Banned
              • Jun 2012
              • 1877
              Recharge your batteries and try it again
              • gbrown2210
                • Jun 2013
                • 18
                So I charged the 2x lipo 2s 5000 as requested and same thing happened. Heres whats going on. When you hit the throttle and then let the prop stop, and hit the throttle the motor starts cogging. It may or may not start or get past that point if you turn the prop by hand and then throttle again it runs.....repeat repeat. Could this be a loose bullet problem?
                • SloHD
                  Slow Electric Addict!
                  • Apr 2013
                  • 337
                  Are the motor/esc bullets the stock 3.5mm still? Or have you changed to bigger?
                  • G-UNIT
                    • 949
                    Push/pull on your motor wires, still sounds like a bad connection since you stated that the motor is cogging.
                    also try and run it with no lipo cut off on the esc.
                    • gbrown2210
                      • Jun 2013
                      • 18
                      I checked them. Here's the thing when it died in the water last night the servo stopped too. Unplugging and re plugging wouldn't have anything to do with the rx/tx. I took a ESC from the hobby shop no longer cogging
                      • G-UNIT
                        • 949
                        so its working ok now?
                        • gbrown2210
                          • Jun 2013
                          • 18
                          And my question to the world and Darin you helped design the MG is the dynamite ESC all that much better?
                          • gbrown2210
                            • Jun 2013
                            • 18
                            and again
                            now my receiver quit working. the motor if you pull the trigger to fast it starts and stops what the heck is going on:bash
                            • lenny
                              • Sep 2010
                              • 4294
                              Did you have any water in the hull after you ran it ?
                              ? ONLY IF THEY WORK
