New system installed!
  • Megabiker98
    • Jan 2013
    • 253
    I got my tacon 4074 2150 kv, t-180 installed. Everything 5.5mm bullets, 2 2s 5,000 mah batteries, but as of NOW my main concern (not huge) but my rudder linkage boot has a little tear on it, if it happens to flip will water get in through there? How would I replace it when I do as it seems connected to the hull pretty darn good!
  • lenny
    • Sep 2010
    • 4294
    You could use it as is and put some rtv silicone or goop on the tear for now to run it,
    Than you order a new one and when you want to replace it just take out the old one.
    And add a piece of tube to the hole and ca it in than put the new one on the tube with ca.
    ? ONLY IF THEY WORK
    • Megabiker98
      • Jan 2013
      • 253
      Ok, will it let any excess water in until that point? Or is it just more of a looks thing?
      • JimClark
        • 5907
        Mine was CA'd on I plan on installing a tube in the hull that the like this
        Billy Graham
        • Megabiker98
          • Jan 2013
          • 253
          That link wouldn't work for me???
          • lenny
            • Sep 2010
            • 4294
            Same hear on the link,
            What coupler are you using in your setup that is not holding the flex shaft tight ?
            Have any pictures of your setup and boat and hardware ?
            Also I set my LV to 2.8 on the seaking 180a and packs come in with 3.88v a cell.
            ? ONLY IF THEY WORK
            • Megabiker98
              • Jan 2013
              • 253
              The stock proboat coupler....how did u know it wasnt staying tight??? 😮 And I'm not sure if it was just because I didn't tighten it enough or not. However I was making sure I tightened it though!!
              • JimClark
                • 5907
                Fixed the link same photo as Lennie had of my boat build
                Billy Graham
                • Megabiker98
                  • Jan 2013
                  • 253
                  Wouldn't that let water in if it flips over though???
                  • lenny
                    • Sep 2010
                    • 4294
                    I had to fix my stock coupler to on my Mystic,
                    You can take it off and the motor and clean out fingers with sand paper,
                    Or a cutting wheel on a dremel, But go easy on what you take out.
                    I ran mine to day and it ran very smooth and pretty fast on 4s2p,
                    Shot some video of it, But it did not come out to good this time.
                    I had the zoom set in a little to close to say with it.
                    ? ONLY IF THEY WORK
                    • Megabiker98
                      • Jan 2013
                      • 253
                      What do u mean by the fingers??? I'm might know what u mean but an not positive!?
                      • lenny
                        • Sep 2010
                        • 4294
                        No,
                        You still put the boot on the tube.
                        Instead of through the hole in hull.
                        ? ONLY IF THEY WORK
                        • ray schrauwen
                          • 9475
                          When the outer part of the coupler is removed, the inner part has gaps and the metal parts that clamp the cable could be described as 'fingers'.
                          Nortavlag Bulc
                          • Heaving Earth
                            Banned
                            • Jun 2012
                            • 1877
                            Install brass tube then slip a new boot on and zip tie it on. So simple it's ridiculous
                            • lenny
                              • Sep 2010
                              • 4294
                              The brass piece,
                              See how it looks open.
                              ? ONLY IF THEY WORK
