well took it out to try it out and i must say i really like this boat handles good seems fast i had 30mph winds yesterday so i was just feeling the boat out mostly didnt get to crazy with it i had already flipped my revolt earlier her is a vid i made driving and filming at same time you can hear that wind blowing set up is seaking 120 tacon 3674 1900kv 2 pole motor with a m445 prop and 4s still got low 40's and could not open it up
Mystic maiden run
im getting allot of lift on this boat on glass water i have the strut down even with the bottom of the boat and the hop starts do i need to lower the strut more or move the batteries forward moreIm Only Responsible For What I Say Not For What You Understand -
ok will try that first i had to fix the trays the other day they both came loose so i re epoxied them down and completely covered them in velcro for just that reason tomorrow is my day off if the weather is good gonna go run it some thanks jet boatIm Only Responsible For What I Say Not For What You UnderstandComment
well dana it didnt work well for me i flipped my boat twice in less than 10 min i moved the strut a little at a time and never could get it to stay down i did get one good pass got 52mph but she was about to flip then also i just got off the trigger b4 it did and i played with the battery placement also to no resolve i dont know what to do now got any more ideasIm Only Responsible For What I Say Not For What You UnderstandComment
im still new to the rc boat world and not shur if this is a problem with rc boats
but i would check the bottom to see if it has a hook in it
when you raised the strut did you keep it level or did it give it some poss. angle???Comment
dose it just ride bow high or it porpoising
nose comes up hook set's it back down and the air picks it back up even higher then it drops then even higher tell blow overComment
