Proboat Mystic 29 with x642 prop ? What you guys think ?
  • Chewwie419
    • Apr 2012
    • 14
    What do you guys think ? A completely stock Proboat Mystic 29 with only a x642 prop s/b will it be ok ? and running on nano-tech 25-50c 6000mah . anything else i should do ?
    IMPULSE 31 V2
    MYSTIC CATAMARAN
    ATLANTIC TUGBOAT
  • Darin Jordan
    • 8335
    If you have the $$ and the ability, I would highly suggest you replace the contacts on the motor leads. Upgrade them to at LEAST 5.5mm...
    With this done, you should be able to run that prop without any issues...
    Darin E. Jordan - Renton, WA
    • Chewwie419
      • Apr 2012
      • 14
      ok cool. i got some castle 5.5 at home. what will happen if i dont change it ? just curious....
      IMPULSE 31 V2
      MYSTIC CATAMARAN
      ATLANTIC TUGBOAT
      • Darin Jordan
        • 8335
        The 3.5's really don't handle the amps very well. They get hot, the solder starts melting, and the wires get loose. You might not notice at first, because the heat-shrink sort of holds them in place. Eventually, they'll separate and could cause the power system to fail with intermittent contact.
        The 5.5's will work well. They handle the current better and "sink" any heat better.
