Trim Tabs on a cat?
  • connorryder
    • 30
    Trim Tabs on a cat?
    Hey i was just wondering if you can out trim tabs on a cat (pro boat mystic).
    Will doing this help the handling of the boat? Or not really help at all?
    Any help would be great!
    Thanks
  • Garrett
    • Mar 2012
    • 126
    it probably would help, tho you could try adjusting the propeller strut. I found that if you adjust the strut down, it makes the boat porpoise more; but if you adjust it up, as awkward as it sounds it does in fact make the boat ride flat.
    I've installed a secondary rudder, using it as a trim tab, and a 2nd water pickup. she dances on the water. its really cool.
    • Make-a-Wake
      FE Rules!
      • 5557
      Trim tabs on a cat is trying to help a bad setup. Adjust COG, strut etc first.
        Four-month-old thread, I'd assume that he's well past the issue.
        • mannytx1
          Fast Electric Adict!
          • Oct 2012
          • 99
          • Spartanator
            • 1060
            Bringing the thread back...
            So I assume that tabs only help during the planing time but also a little "bounciness"?
            I have a 32" Rivercat but I run in the choppy waters so I can't really get on it or it gets in the air...
            Would a led weight help up front?
