been running 5s5000mah with a spartan prop with stock motor and esc plenty of fun but just got a seaking 180 amp and going to 6s5000mah35c(2 3s) what would be a good motor for this setup just for general bashing and maybe some all out runs
what motor
What boat???? You state that you are running a "Spartan prop" and some "stock motor"....................is it a Spartan?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
This one may work.................Attached FilesNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
But seriously, this Leopard 1400kv on 6s would be almost uncontrollable: http://www.offshoreelectrics.com/pro...o-4074&cat=148
I'd go with a 3674 if it were mine, the 1400kv and you could swing a 6 pitch prop with some decent diameter............plus it would probably go right into the stock mount being a 36mm http://www.offshoreelectrics.com/pro...o-3674&cat=148NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
They are real, and they are used in Big-A$$ airplanes mainly, here's a whole page of big outrunners http://www.hobbyking.com/hobbyking/s...idCategory=522NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
its a good motor but unless you are spec racing go with the leopard. I have a 4074 2000 kv on 4s and am not sure why anyone would want to make the boat faster then that, pretty damn fast for a 29 inch boat.Comment
