Hate my Proboat Mystic
  • Boatlover
    • Feb 2012
    • 48
    i have a leopard 4074 2200kv and running 4s and i cant keep this thing from bouncing. i have moved to batteries forward and back with no luck. i have raised to prop up and down with no luck. i wish i could pay someone to set this thing up right. it sucks to have $800 bucks in a boat (boat,motor,esc,batteries,props) and it runs like crap. i live in florida any sugestions. does someone have pics of their miss geico or mystic battery placement and strut angle?
  • Rumdog
    • 6453
    Here is my suggestion: Put the stock gear back in it, and run it. It wasnt designed to run on that much power, and unless you are experienced with setting up boats you'll never get it right unless by accident.
    • Boatlover
      • Feb 2012
      • 48
      i see people on you tube running the miss geico 60 plus without the bounce
      • TheShaughnessy
        • 1431
        you can't have any pudding unless you eat your meat
        Just so you know no one on this forum is going to respond to you, here is why. 1 you are posting in the wrong area. 2 you have a negative attitude. Any body that has the set up info is now offended that you hate the very boat they love so why give you the info.
        Well you haven't bothered with the drive angle yet so go ahead and start trying stuff there. Trying the batteries in 3 positions and the prop in 4 (i made these numbers up assuming you gave up without trying much) doesn't count as trying every set up. You haven't changed the caster on the rudder.
        So there are 4 variables (you adjusted 2) and each of the 4 has 5 or more positions it could be in. Over 100 different combinations between the 4 components and I know you haven't tried them all because if you had you would have eventually found what works.
        • TheShaughnessy
          • 1431
          I was thinking the same thing. Gave himself too much motor, doesn't know what to do and now he is mad at the boat, typical. Stupid boat that works for everyone but me. Yep must be the boat that is stupid*!**
          • Boatlover
            • Feb 2012
            • 48
            sorry guys i dont hate it, i love it i just hate that its not running the way i think it should. just asking for help. i just want perfection and am looking for any help.
            • Boatlover
              • Feb 2012
              • 48
              ill keep trying, i havent tried the strut angle though. you think that might change the attitude?
              • FRED
                • Jul 2007
                • 233
                I agree on the power and next, i would get some carbon fiber props. try using 4 pitch. Like you say $800 invested and would drop down on prop size. Don't move the lipos but would try going a hair on negative strut . Do take 1 step at a time. Write down on paper each change you make.
                • MORIDE
                  • 102
                  Take a look at you hull
                  I have a MG and Mystic run on 5S and sometimes 6S on stock motors but 150 and 180 amp ESC's, I have not had a problem with bounce that I have not been able to cure with battery placement or strut height, Maybe your hull has an issue. What prop are you running?
                  • Boatlover
                    • Feb 2012
                    • 48
                    X642 and the leather 215
                    • slowride
                      • Jun 2011
                      • 84
                      Where in Florida ? I might be able to help if you are close to Cape Canaveral.
                      • Boatlover
                        • Feb 2012
                        • 48
                        I live in Tally. Is there any way to get that guys # "Tiqueman". Also slowride if your interested we can work something out if you what to PM me i can give my # and we can talk, that would be great.
                        • jasoncyclone
                          • Jun 2011
                          • 475
                          I think you will take care of the bounce by adjusting strut angle..... It worked for me. Can you post some pics of the rear of your boat??? That would help.
                          Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
                          • Tim K
                            • Aug 2011
                            • 26
                            Put the boat on a flat surface , loosen the strut and push it down flat to the surface its on.
                            Tighten it up and scribe a line on the strut to use as a reference.
                            This is a great starting position on any Cat.
                            When testing slowly raise the strut keeping the line level with the bracket until you are happy with the performance.
                            I have had a number of Cats over the years , they all were set up this way with zero strut angle and they all performed very well.
                            Good luck
                            Toy boats
                            http://www.youtube.com/watch?v=1PrL4KQtQu0
                            • domwilson
                              Moderator
                              • 4408
                              Do you have some vids of it running or some pics of the side and back view of your strut? That would be helpful in others helping to solve your issues.
                              Government Moto:
