Miss Budweiser Mystic 29--what's the best prop?
  • Brad
    • Dec 2011
    • 47
    Just finished the Bud scheme. Is the x642 the best prop for the stock electronics?
  • ray schrauwen
    • 9472
    Not sure what "best" prop is depending if you want speed or run time or the happiest medium between the two.
    Your Bud scheme is really nice man, great choice!
    Nortavlag Bulc
    • Brad
      • Dec 2011
      • 47
      A bit more speed out of the stock electrics would be welcome. The esc and motor have yet to hit 80 degrees on an all-out near-10-minute run on 6000MAH batteries with the stock prop. Love the way the boat handles. I am prepping the stock prop this weekend, was just waiting for my new balancer.
      I also have the Spartan, and we have that up to 55 MPH with some minor mods/prop, and that's plenty fast for water. Sure some dudes are talking about speeds MUCH faster than this with other props and big motors, but bad things can happen on high-speed crashes as well!
      • ron1950
        • 3024
        try a m445..i have the 1800 motor in a geigo with the m445 and it runs pretty good...watch your temps as always.....i run mine 4 and a half to 5 min and its prob 120 or so degrees
        • Make-a-Wake
          FE Rules!
          • 5557
          I'm gonna say the 642 is as close as you'll get to the "best" prop with the stock electronics...............although Ron's suggested m445 may work very well too.
          • HUNTER
            • Jul 2011
            • 12
            You could also consider a Grim 42x55, tried it on mine and it picked up 4mph over a X642. Temps were a bit high, but we were running in very warm water. M445 was another 1.5 mph faster than the grim, but it was hotter again. I usually just run the X642 unless i want to do a couple of speed runs.
            • Make-a-Wake
              FE Rules!
              • 5557
              You may give a Prather s220 a try.................... http://www.offshoreelectrics.com/pro...i-prather-s220
              • Boatlover
                • Feb 2012
                • 48
                I put the grim 42*55 on there from the day I bought it and it won't stop bouncing at high speeds. Do you think the prop is the problem? I can't run the boat at full throttle with out it wanting to flip over, even with the batteries all the way up front. Please someone tell me what to do to stop the high speed bouncing. The last thing I can do is to put the stock prop back on and test it. Any advice?
                • ray schrauwen
                  • 9472
                  Have you tried raising your strut a little bit?
                  Nortavlag Bulc
                  • Brad
                    • Dec 2011
                    • 47
                    I moved the batteries forward, and never had a problem--even hauling ass with my 4074 2200kv with a 445. What batteries are you using, I use 5600 or 6000 mah. Try the back of battery forward to where the flex shaft meets the collet. Generally speaking, catamarans will bounce a little bit due to the hydrodynamics of the hulls. My shaft is even with the bottom (put on a table and the shaft and the bottom are same level).
                    • cmorris
                      • Feb 2012
                      • 23
                      I got the 445 and balanced and polished it and here it is..... on my second run for the day I had a blow over after crossing the wake of my buddies Geico but it was flat out flying, literally!! I did notice that my run time was alittle shorter but it sure dug in.
                      • Make-a-Wake
                        FE Rules!
                        • 5557
                        That's one purdy prop!
                        • cmorris
                          • Feb 2012
                          • 23
                          spent about an hour under a microscope to thin out the edges, knife edge and then put a high shine on it, now it really sings
                          • Brad
                            • Dec 2011
                            • 47
                            I get my props razor sharp, but I only shine a bit with some WD and Scotch brite, along with super fine sandpaper. What steps do you use get the incredible mirror shine? Damn, that's the nicest prop I've ever seen!
                            • ray schrauwen
                              • 9472
                              Nice prop work Mr.Morris
                              Nortavlag Bulc
