So ive tried just about every combination of battery location and strut angle and height and its still wanting to bounce out the water at WOT when going in a straight light.
Yesterday i did find that some of the water splashing up on the back side the boat is actually come from the strut, so when i get time im going to sharpen that. I also have been told that installing a offset rudder will help alot of my issues. Any chance someone can point me into the right direction to find a offset rudder that will work on my boat which i believe to be a V2. I dont see anything listed in the OSE Store. If the offset rudder doesnt fix the bouncing ill just have to spend the time and blueprint the hull. The problem is i think ill have to remove to much material to get it flat which would make the hull paper then in areas if not a hole.
I picked up a X442 prop that im going to try but i need to sharpen and balance it first.
@eehess81 I understand that angling the prop down with lift the back more but it would also lower the front, my thought process was thinking if i can keep the front down by adjusting the prop angle i could move the batteries all the way back to help keep the back down.
When i first got the boat i only ran it on 3S(2 3S Traxxas ID batteries in parallel) with the stock prop and it ran flat! I think it ran flat because of two reason. One being that the batteries i got with the boat are much heavier than the batteries i have now and it was slower on 3S. Id bet that both of my new batteries combine weigh less than one of the Traxxas batteries.
Wayne
Wayne
