Well I got about 8 runs out of my Miss Geico V3 on 6s and the Dynamite motor decided to exit stage left. These 2000kv motors can not handle the heat that is produced. I even improved on the cooling system with larger tubing and running t the esc first. The esc and batt temps were within range but the motor just heats up no matter what you do. I have been running 2 3s 5000 mah 50 c as they suggest in the instructions. It is basically a good boat that just needs a few improvements. They need to lose the 12 guage wire first off. I do like the esc, but pro boat's quality control needs to be improved. The motor shaft in the Dynamite motor had a lot of play in it. I could push it into the motor about an 1/8" then pull it back out. I can see a little play but that is excessive. I have put in a request for a new motor buy I am leery of running another dynamite motor. I have ordered a leopard 3650 1650 kv to put in there for now so the rpm and amp draw will not be as high. Like I stated earlier be careful running on 6s.
Miss Geico 29 V3 on 6s - be careful
Miss Geico v3, Impulse 31 v2, AQ Motley Crew, Atomik Barbwire
Tags: None -
I would suggest running a seperate cooling line to the motor, even with the new motor. It is simple and cheap to do. -
Well I called Horizon Yesterday and explained the situation. They quickly agreed to ship me a new motor, apparently I am the first to blow a motor on the MG 29 V3. They said it shouldn't have happened. I have the new Leopard 3650 1650 kv on the way but I am not sure which motor to put in now. I have taken Xcessive Carts advice and ordered a transom pickup so I will have separate water lines and exits which should greatly improve the cooling for either motor.. Should I just put in the leopard motor or give the replacement Dynamite a shot?Miss Geico v3, Impulse 31 v2, AQ Motley Crew, Atomik Barbwire
Some info you are not talking about is how long are your runs? And are you running full speed most of the run?
Sent from my SGH-M919 using Tapatalk"Our society strives to avoid any possibility of offending anyone except God.
Billy GrahamComment
My run times are just under 5 minutes. I am using 3s 50c 5000mah batteries. I am at full throttle at least 95% of that time.Miss Geico v3, Impulse 31 v2, AQ Motley Crew, Atomik Barbwire
I haven't gps'd it yet but I would say she is easily doing at least 50 mph give or take. She is very stable on the water. I am using the stock prop.Miss Geico v3, Impulse 31 v2, AQ Motley Crew, Atomik Barbwire
If you don't mind doing a little modding, this is my upgrade for my BJ29 v3. The motor and ESC don't run hotter then about 85° on dual 2s, even after a second set. I haven't tried dual 3s yet. Now that could change as the lakes get warmer here.Comment
It's a Speedmaster small extended dual pickup rudder assembly from OSE. And I had to modify it a bitComment
