Does anyone know a dual pickup rudder that fits the MG? Maybe one that will fit the stock rudder bracket? I really want to do a separate cooling line for the motor and for the esc. I would really rather run a dual pickup rudder than a second separate pickup, for drag reasons. Any help would be appreciated.
Dual pickup rudder?
You can get the big 6 incher from here on OSE and hack off an inch and a half or so, I've done it once, works fine.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
http://forums.offshoreelectrics.com/...est!&highlight= -
Here's the tapered one you can use, you can cut it off at the shadow edge where i put the line, or somwhere in there, then you smooth it out and shape the bottom of the rudder as you choose. You can buy the "blade only" for $24.95
http://www.offshoreelectrics.com/pro...s-rud-dual-tapAttached FilesNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
http://forums.offshoreelectrics.com/...est!&highlight=Comment
Nortavlag Bulc
