Motor whinning out?
  • nitromt
    • Jun 2012
    • 17
    Motor whinning out?
    When i drive my mg coming out of a turn and i go to pin it it seems like the motor is whinning out and the boat doesnt move much ease off the throttle then apply throttle is goes fine then any ideas what this might be?
  • masonis1
    If you cant control it 👍👍
    • 1173
    thats the prop cavitating i think. mine does that, just lay on the throttle and it will get up. just needs to start up. the.motor is fine. now there might be something dofferent. i might have misread it but i think.its kust cavitating. what prop are you running?
    Sent from my SPH-D700 using Tapatalk 2
    • nitromt
      • Jun 2012
      • 17
      Hey sry for late reply the prop im using is aquacraft 42/55 but i believe it did it with the stock prop as well.
      • phil english
        • Sep 2012
        • 8
        i am haveing the same problem just order a new flex drive and connector i will try this to see if it resolve the problem i call proboat to see if thay had a solution thay told me to check the tip of thr flex drive for grease that may have got on the motor connector my mg is only 2 months old thay are sending me a new flex deive and motor connector for free to try
        • phil english
          • Sep 2012
          • 8
          Hi well i replaced the flex drive and connector still haveing the same problem my mg is on the way back to proboat so thay can troubleshoot and resolve the problem i will let you know the finding .
          • masonis1
            • 1173
            It's the prop caving, it is spinning faster than it can hook in the water in a sense.
            • phil english
              • Sep 2012
              • 8
              I don,t understand it does happen all the time the first laps is fine if this was a prop caving problem wouldn,t it have happen from the start.
              • masonis1
                • 1173
                Well you did t tell us that. That could be the esc. What kind of esc u have
                • phil english
                  • Sep 2012
                  • 8
                  The stock one that came with the boat
                  • domwilson
                    Moderator
                    • 4405
                    Can you post pics of the back and side of your boat so that we can see your strut and rudder alignment?
                    Government Moto:
                    • phil english
                      • Sep 2012
                      • 8
                      The boat is on the way back to horizon to have it check out
