Blow Esc????
  • Big Lebowski
    • Apr 2012
    • 62
    Blow Esc????
    How do you know when your esc has failed? No beeps when i turn on boat, only steering and no throttle. 45 a 1800kv 4s2p 25-50c 6000mahs. When i towed boat in temp on esc was 100 boat sat in the water for 15 mins before i got it in. Any advice would be appreciated. Thanks!
  • lenny
    • Sep 2010
    • 4294
    Pull water line off motor that go's to the esc,
    And see if you can blow though it.
    If its not block you may be in luck,
    Than try and reset or bind the tx to rx.
    ? ONLY IF THEY WORK
    • JimClark
      • 5907
      The 45 Amp (Proboat)? On an 1800kv motor? probably a bit much for that ESC to handle
      Billy Graham
      • JimClark
        • 5907
        This is not the For Sale Forum if you have something for sale then list it in the FS Forum this is a discussion.
        Two posts have been deleted
        Billy Graham
        • JimClark
          • 5907
          Go to the FS Forum if you are looking for a ESC not here
          Originally posted by Big Lebowski
          How much? I really don't need it. I have a seaking and Leo setup. Thanks
          Billy Graham
          • dana
            Banned
            • Mar 2010
            • 3573
            IMG_1698.jpg heres the pic i promised
            • Big Lebowski
              • Apr 2012
              • 62
              Originally posted by dana
              [ATTACH=CONFIG]76802[/ATTACH] heres the pic i promised
              Thanks Dana
              • dana
                Banned
                • Mar 2010
                • 3573
                Do you need a pic of a series and a parallel battery wiring?
                • Big Lebowski
                  • Apr 2012
                  • 62
                  Yes parallel please. Can you also take a picture of your battery end setup. Thanks again dana
                  • Big Lebowski
                    • Apr 2012
                    • 62
                    What kind of remote is good?
                    • dana
                      Banned
                      • Mar 2010
                      • 3573
                      tactic remotes work well.
                      heres a series and a parallel battery wiring setup
                      pic 1 is series. pic 2 is parallel
                      • dana
                        Banned
                        • Mar 2010
                        • 3573
                        pic 1 uses two 2s packs to make 4s1p
                        pic 2 uses two 4s packs to make 4s2p
