Up in smoke
  • karlhh
    • Dec 2011
    • 99
    Up in smoke
    So today im running MG for the first time on 5s sky lipo 5000mah 45c fast she was. hard to keep the front down fliped once going against the wind. had batteries moved 1 inch off the front battery trays still light in the front. so after running for 5min lost half power so brought it in took the hatch off filled with smoke. running seaking 180 m445 prop and proboat 1800kv motor notice motor was hot and three lead wires burnt. So you think 5s was much for 1800kv or faulty motor. no in the market for a new one. I as liking the leapard 4074 2200kv but now not knowing how it will do with running 5s. top speed on gps was 53.9 thanks.
  • Rumdog
    • 6453
    with that prop, 5s is too much for that motor.
    • karlhh
      • Dec 2011
      • 99
      The prop is a m445, 5s is to much for that partictiler motor or 1800kv in general? whats your thoughts on the leapard 2200 kv 4074
      • Rumdog
        • 6453
        that would be a good 4s motor. (the leopard) 5s may have worked well with your motor, but a m445 was too much prop at 5s.
        • karlhh
          • Dec 2011
          • 99
          So ya think I should go with the leopard drop the prop size to like a x642 then 5s or keep m445 and run 4s with the leopard?
            • 7673
            I only run 4s with my CC1515 2200kv.Tried 5s once and uhh,boats a new colour and alot stronger now.You should be able to get a 4074 rippin plenty good.Mines about 57mph.
            • karlhh
              • Dec 2011
              • 99
              With a 4074 2200kv on 4s should i be able to run the m445?
              • Rumdog
                • 6453
                yup. It would be fine. If you really want to run 5s, go with a motor around 1800kv.
                (gee, another moved thread)
                • karlhh
                  • Dec 2011
                  • 99
                  Ran my geico today for the first time with leo 2000kv on 4s took off the m445 and used x642 speeds where 48mph. Like to get back to the mid 50s temps. on motor around 108F never tried my m445 prop do you think that would raise temps to much? or shouuld i try to tweek 5 mph more out of the x642?
