I have a leak somewhere am not really sure how to pressure test my fuel tubing. I'm assuming its my tubing as I don't see any cracks in the haul but its a pretty big leak? Thinking an air compressor might be a bit much but visually it looks like all my water lines are hooked up I have zipties on each nipple, they all appear to be tight and well secured? Thinking I must have a cracked line somewhere?
How to pressure test the water lines?
I use a little squeeze bottle that has a nozzle that fits right into the tube. You could use a syringe or something as well. force the water through and if you want you could pinch off the outlet end and force the water..if nothing goes through or it forces back out the end you are putting the water in at, then you are leak free...if not you should be able to tell where the leak is pretty quickly.The Speeders
*PB SW 26 BL *PB Formula FASTech
The Cruiser
*CBM Marlin Cruiser
The Pool Toys
*Proboat Mini-C (x2) Comment
A large syringe seems to do the job just fine, and it's cheap...Darin E. Jordan - Renton, WA
If I need to tighten the water line fit, I usually cut a short section of the fuel tubing and place it over the original fuel tubing. For the pressures we experience, this seems to work fine.Darin E. Jordan - Renton, WA
