leapard 4074
  • skyhighdiver
    • Jun 2011
    • 287
    leapard 4074
    will the leapard 4074 fit on the standerd mount in MG or do i have to replace it
    info please
    Thanks in advance for anyone
    Miss Geico (now white) Leopard 4074 2200kv motor T180 esc,x642 54.6 mph
    Miss Geico 2(now black and white)4074 2000kv motor, T180 esc m445 51.2 mph
    FAT PEOPLE ARE HARD TO KIDNAP
  • lenny
    • Sep 2010
    • 4296
    I think it will work ok, But you should find away to support the back can of the motor.
    So it does not move up and down, I used a zip tie and a wedge.
    ? ONLY IF THEY WORK
    • Big Lebowski
      • Apr 2012
      • 62
      Can you take a picture of were the zip tie and wedge is? Planning to put the same motor in. Doesn't leopard make heavy duty motor mounts?
      • skyhighdiver
        • Jun 2011
        • 287
        I went with this set up and love it 4074 t180esc m445 and 2 4s 4500 nanoteck runs 54
        get 4 minute run times x 2 as batterys need a cool down or start to get puffy, run about 120-130 at 4 to 4.5 minutes everything else stays cool 100-110
        I did add extra water pick up so motor and esc are seperate.
        I was going to use the osc motor mount as i did get it but ended up just using the ends, as otherwise would have required me to remove the wood from inside
        I wanted to be able to move stock motor or the 1800kv in also so this set up works fantastic.just 3 dollor piece of alum epoxyed in at back.
        Have had many 40+ mph flips and all stays well.
