Proboat miss geico sponson seam are spliting open
  • CHIEFY_44
    • Nov 2010
    • 254
    http://forums.offshoreelectrics.com/...+of+miss+gieco
    this is the thread where darin explains everything you need to do with a MG
    Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
    • Diegoboy
      • Mar 2007
      • 7244
      Darin's race prep thread now stickied
      • desmobob
        • Sep 2011
        • 170
        ...if you do about a 30oz pour of 2-part 2lb foam down the seam on each side, pouring it in just in front of the trays and rolling it forward to the tips, then leaving the boat on it's side while the foam expands, then repeat on the other side, you'll about have it. With the foam contacting the sides, bottom and just under the deck, the front of this boat becomes much more solid. I made a final pour of about 20oz up under the deck...
        30 oz. of foam mix down each side? 20 oz. under the deck? I don't think that much would fit in the hull... Are those figures correct?
        Take it easy,
        desmobob
        • JIM MARCUM
          • Jun 2011
          • 773
          Darin, you told me how to do this at the SAWs, but it's better to see your foam sequence in writing. I'll probably start with a 1" fiberglass tape & epoxy on the inner seams first. Also, just got a Blackjack to run in N-2 Offshore class & it looks like the the seams are re-enforced with a 1/4" "V" shaped seam stiffener. My Miss G should work well on an oval course with my SAW setup. Hey, 52 MPH on my virgin run ain't bad. Again, I really appreciate your help & advice at the SAWs. Nice guys DO win!!! JIM
          JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
          • Darin Jordan
            • 8335
            Take it easy,
            desmobob
            Hahaha... I think I meant cc's.... Sorry... still recovering from driving for 20 hours straight on the way home from LA!
            Darin E. Jordan - Renton, WA
            • desmobob
              • Sep 2011
              • 170
              Ah... that makes a lot more sense! 20 hours of driving would make me unable to even type, let alone remember volume measurements....
              One of my buddies' Mystic hull split at the bow from sponson to sponson. Of course, he ran it into the bank at full throttle!
              I'll be adding some foam to mine, just to help insure the longetvity of the hull. I love it and don't want it to come apart!
              Take it easy,
              desmobob
              • JIM MARCUM
                • Jun 2011
                • 773
                Glad you cleared that up Darin. When you told me how to fix my MG at the SAWs I think you said OZ. CCs make a lot more sense. I'm building the ProBoat Blackjack hull to race in the N-2 Offshore class. What do you think of that hull for racing, and which hull would you recommend as the best for Offshore oval racing? Send me a private message if necessary. THX, JIM
