So I have made this response on a different thread and got to response so I am starting it here as a stand alone
If you put a y in your line from the water inlet and then feed to motor and esc with separate lines is this not robbing both of cooling?
My thereby is this, water like any other fluid takes the path of least resistance. If I put a Y in the line and use two outputs the rudder can still only pick up so much water by splitting it you already in effect have cut the supply in half and if motor and esc lines are not same length you cut the water supply to the longer line more. Therefore although you may be feeding slightly warm water from the esc to motor on a single line you are getting more flow is this still not better than putting in Y and less flow.
What are you guys doing?
