2 (4s) in parallel, will they fit???
  • wrxwhit
    • Jun 2011
    • 25
    I have a Miss Geico and dont want to modify the battery trays yet. Will two 4s 5000mah batts fit with no modifications to run parallel?
  • skyhighdiver
    • Jun 2011
    • 287
    yes but its tight and getting out is worse than getting in but they will fit also can stck 2 2s and that fits
    Miss Geico (now white) Leopard 4074 2200kv motor T180 esc,x642 54.6 mph
    Miss Geico 2(now black and white)4074 2000kv motor, T180 esc m445 51.2 mph
    FAT PEOPLE ARE HARD TO KIDNAP
    • maxmekker
      • 412
      I will receive my 2 zippy 4 s 4500 today. will post picks.
      Drammen rock City
      • maxmekker
        • 412
        here are my 4000 4s zippy. I said 4500, but it was 4000.
        IMG_0085 (Medium).jpgIMG_0084 (Medium).JPGIMG_0083 (Medium).JPGIMG_0081 (Medium).JPG
        Drammen rock City
        • CHIEFY_44
          • Nov 2010
          • 254
          i know the nano tech 4000 fit no problem
          Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
          • wrxwhit
            • Jun 2011
            • 25
            Thanks for the great pics Max, very helpful. I am gonna try to squeeze some 5000mah in there!
            • maxmekker
              • 412
              I found it was a tight squeeze to get them in and out because of the side woodwall. Winter projeckt to rip it all out and lower the trays and install another motormount to give more space. Hope to test them today and see if they help with stability.
              Drammen rock City
              • wrxwhit
                • Jun 2011
                • 25
                I am inteseted in how the stability worked out with these and what your run times are? I really want to buy 5000mah 40c for max run time. If your saying the 4000mah barely fit in, then 5000mah may be a nightmare. I may just buy em and see what happens, then modify if i realllllly have to. Also cant wait until my Mystic comes in to play around with Miss Geico, HAHA!!!
                • CHIEFY_44
                  • Nov 2010
                  • 254
                  i don't know about 5000 4s if they will fit or not i do use 4s 4000 and they can be a real pain to get out if in a hurry, because i used 4s2p i dont have a problem with stability its still very stable and corners very very good
                  • maxmekker
                    • 412
                    Sorry for the zoomed in. The two other clip's were corrupted,but you get the idea.
                    Drammen rock City
                    • wrxwhit
                      • Jun 2011
                      • 25
                      Very nice Max, thanks for the vid. I have the same setup as you. Just got the m445 prop in the mail a couple days back. What is the approx run time with the 4000mah?
                      • TheShaughnessy
                        • 1431
                        I fit 5000 mah packs in mine 4s2p, I think the 4000's might almost be better though.
                        • wrxwhit
                          • Jun 2011
                          • 25
                          Shaughnessy, do you have these batteries velcro strapped down or just velcro on battery and tray? What C rating are they? You said 4000's may be better becauase of handling or fitment? Sorry for all the questions!!
                          • Peacock8
                            • Jun 2011
                            • 97
                            I use two 5000mah in parallel and they fit. Nano techs. But its a squeeze. I broke off one of my battery trays in a flips so I think I´m going to remove the other one also.
                            Ørjan.
                            • maxmekker
                              • 412
                              Both of mine came loose in this flip(at the end on 5s) I think I will ,as a winter projeckt , rip them out and lower them to make it easy to get the lipos in and out. But I like to have them above the bottom og the hull in case of a leak etc.
                              Run time, well , I brought it in to have a look at the temps, and the boat was filled with water.No more grease on the flex, so the water came up the flex. I feel like I greas the flex well, and often, but I had to call it last night.so I dunno the runtime.
                              I just used velcro on the pack's , but I feel like they might need to be straped down to.
                              Drammen rock City
