After reading and reading and reading this forum I am more confused now than when I started.
So I’m going to give you my take and then PLEASE correct me if and were i'm wrong
I am running a stock MG exept for prop x642 (done fantastically by the ice329)
I run 2 2s 5300 packs in series
Everyone here seems to say run 4s packs in parallel you will get longer run times. I don’t know if it will be faster but will run longer
My thinking is if I run 4s packs I’ve doubled my battery weight thereby slowing down the boat. So now I need a bigger motor to make up the speed, but then I need bigger batteries to run the bigger motor and so on so on
So does moving up to 4s really make it worth the price or should I just buy more (inexpensive 2c) and change them every 9 minutes as this is the run time I’m getting with this set up.
And not to open another can of worms but do I need to upgrade to 5m plugs and to what advantage to I gain if I stay stock by changing
I truly thank you all for your insight
