M,iss geico+7040 200kv. What prop on 4s/5s ?
  • maxmekker
    • 412
    So I smoked my stock 1500 kv motor in the Geico. Went 5s at once with the prather 230, and it lasted 2 minuts. Great fun as long as it lasted :-)
    Anyway, I have these items:
    nano: 2x 2s and 2x 3s, same C and 4000Mah
    Turnigy: Same as above.
    Orion: rocket pack 4x 2s 5000mah
    Props: All S/B
    Prather 215,230
    642, m445
    42x55 on order.
    Kintec Flex + offset rudder.
    4070 2000kv
    I want to run both 4s and 5s. Any prop adwise would be great. The 215 was just something I had from the Surge Crusher,so it's not much used.
    The 642 helped out on the bounce a bitt,and the 445 is in the mail, so I have not tried that one just yet.
    The 230 was great fun, can the 4070 swing it on 4s ?
    Ore is it to much ?
    Any other prop I should have a look at ?
    Thanks for having a look.
    (Sorry about the heading in the tread, how can I edit that ? )
    Stian
    Drammen rock City
  • ron1950
    • 3024
    with a 230 and 5s u are going to smoke that 4074 also...ditch that 230 and get a m445 and go 4s u will get all it can take lol
    • maxmekker
      • 412
      Ready to go.
      Drammen rock City
      • Stone
        • May 2011
        • 5
        Nice setup, looks like a million dollars ;-)))
          Switch the cooling lines on the motor. Set up the way you have it the jacket may not stay full of water when running. The exit needs to be at the top to keep the jacket full all the time.
          • maxmekker
            • 412
            Done and tested in poring rain today. All good on 4s + 642
            Just got the prather 220 , m445 , x442 and last 42x55 prop on order. That should cover me on the miss gecio and it's nice to have the props that has been mentioned in treads in the toolbox.
            But if there are any other props that can be nice to have on 5s setup , shout out
            Drammen rock City
            • Alexgar
              • Aug 2009
              • 3534
              442 on 5s less pitch on the high revs might surprise you or a 440
              • maxmekker
                • 412
                A short clips from last night.
                Drammen rock City
                • Phaleronic
                  • Jun 2011
                  • 39
                  Great vid and fast boat. Looks like Lake Wenatchee. :)
                  • maxmekker
                    • 412
                    Thanks mister.
                    Well it's in Norway.
                    Drammen rock City
                    • maxmekker
                      • 412
                      4s + 642 , and then 5s with prather 215
                      Drammen rock City
                      • bbosncali
                        • 756
                        M445 all the way.... For me that was the best all around prop now I use a m645 more pitch but I also have more motor
                        miss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717
                        • Peacock8
                          • Jun 2011
                          • 97
                          Any difference from the stock prop, I´v heard that it´s similar to the stock prop. I have one but haven´t gotten around balancing it yet. Started on the 42-55 and X642.
                          Ørjan.
                          • bbosncali
                            • 756
                            Which prop are you referring too???
                            • Peacock8
                              • Jun 2011
                              • 97
                              Ahh, sorry was talking to maxmekker about his prather 215 :)
                              Ørjan.
