Hello,
I recently purchased the Kinetic greaseable bushing. I was wondering if someone could make any suggestions on how to remove the stock bushing from the strut? I have tried catching the inner lip with a flat head and tapping it out with no success. It seems to be in there really good.
Thank you!
Pete
Thank you!
Pete
? It is really close in size to the stock one but the part that screw goes though was not wide enough to fit the stock mounts and the mounts that came with it would have pushed everything back and would have required me to drill holes so the rudder would mount it. I opted to grind the inside part down about 2-3mm. The stuffing tube looked to be about 1mm smaller then the new strut. It probably would have worked just fine but I added a little clear heat shrink to ensure a good seal and no problems.
.. Down side was my drive shaft broke after about 2 min sinking to the bottom of the pond with my prop
My fault I noticed two small chunks/dings out of it last night but did not realize how easy this would break
