4s (38.1mph) and 6s (54.7mph) video
  • wppracing
    • 109
    Here is the visual diference between a 4s and 6s run
    Watercraft Performance & ATV
    wppracing.com
  • ron1950
    • 3024
    get ya a ul-1 motor and with 4s u can get it up to 47...no telling what orbital condition u can get with 6s
    • brian6989
      • 85
      do you mind telling me what kv motor your running man that thing is flying on 6c
      washed up factory racers edge driver.. past LHS owner now im back to the hobby I love
      • wppracing
        • 109
        Stock OEM motor
        wppracing.com
        • TheShaughnessy
          • 1431
          a ul1 motor on 6s would let some magic smoke out. 46000+ rpm would reck something for sure.
          • budman10
            • Dec 2010
            • 11
            what kind of temps were you geting on the motor and controler and what prop im geting ready to run a set up kind of like that ( when i get more time) lol
            • wppracing
              • 109
              Here is the 6s set up:
              1. 6s with (2)11.1v 40c 5000mah and 7.4v 40c 5000mah hard case lipos
              2. Stock OEM Motor
              3. Sea King 180a ESC ( settings 1-forward, 2- 5 cell, 3- 3.4v low voltage cutoff, 4- 11.25 timing )
              4. 1600mah Receiver Pack (BEC removed)
              5. Relocated Water Outlet
              6. Kintec Offset Rudder Bracket
              7. 4mm water line
              8. M445 Prop
              9. Trued Hull, Fiberglass Sheet reinforced Canopy, Front part of hull filled with spray foam.
              10. Total Boat Weight as listed 6.4lbs
              Motor Temp was 110deg
              ESC was 89deg
              wppracing.com
              • tiqueman
                • Jul 2009
                • 5669
                Very nice wp. You can do quite a bit of tweaking and get a bit more out of 4S. Stock motor Im at 44mph. Im running 4 minute LSO heats and its doing pretty well temperature wise. the motor wires are the only things really suffering. But Im really happy with it.
                • tiqueman
                  • Jul 2009
                  • 5669
                  We posted at the same time. You defintiely have something wrong if your only turning 38 mph on an M445. Be sure youve calibrated your throttle on your 180. Deisel was having an issue w/ his Pursuit in it not running like everyone elses w/ the same set up. He found that even though he calibrated, it didnt calibrate correctly. He did it again and picked up quite a few mph. You may be able to get closer to the 60 mark?!?
                  • Darin Jordan
                    • 8335
                    Put the right prop on it, and you can do that with the stock motor...
                    Darin E. Jordan - Renton, WA
                    • wppracing
                      • 109
                      On 4s it runs 40.4 mph with a 42/55 I never ran the M445 on 4s and only had a video of the X642 4s set up.
                      wppracing.com
                      • ron1950
                        • 3024
                        i never recomended the 6s set up with the ul-1 just 4s...
                        • wiskers
                          • Feb 2011
                          • 32
                          Here is my setup and tests. Where do I go from here?
                          Initial setup Stock MG out of the box 4000mah 25c (x2) batteries in the middle of the trays = 30.1 mph aggressive bounce.
                          Adjusted the stuffing tube to table top level, placed batteries forward of 9” COG line = 31.4 mph almost no bounce.
                          In all subsequent tests best speed and performance was with the batteries forward of the 9” line.
                          Prop selection and best speeds are as follows: (this is the order tested as well)
                          PB 1.6x2.5 composite Stock 30.1 mph
                          PB 1.6x2.5 composite sharpened and cleaned up 31.4 mph
                          PB 1.9x3.0 composite filed to 45mm dia & sharpened 39.1 mph
                          GR 42x55 balanced & sharpened 37.7 mph
                          Octura M445 balanced, sharpened & thinned 39.3 mph
                          How big a prop can the stock set up handle. I have an old X452 that I plan on modifying. Grinding down the dia & maybe de-tongue it somewhat or a lot.
                          Any help would be appreciated.
                          • nycow
                            • May 2011
                            • 2
                            MG drive setting...
                            Hello everybody,
                            I also have an MG (initial setup stock) , and i have some questions about the settings...
                            when you say "Adjusted the stuffing tube to table top level" that's mean that you remove the prop and the rudder, then you put the boat on a flat table, the bottom of the drive is at the same level than the bottom of the sponsons ? ( green line is same as red line )
                            Isn't there any negative or positive angle of the drive ? I made a little sketch ...
                            ( sorry for my english i'm french )
                            Thanks for your help
                            • wppracing
                              • 109
                              Loosen the strut bolt and set the boat on a table with the rudder hanging off it. The strut will now sit level with the hull.
                              wppracing.com
