can someone tell me how much gap should be between white washer and the collet that holds the prop
how much gap
if u mean between the white washer and the drive dog its around 1mmSocal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180Comment
hold the motor collet still with a wrench, turn the prop a little and you will see it compress, make sure your gap is enough to handle that compression. I'd go closer to an 8th inch.Comment
