Gave up on Spartan
  • brian6989
    • 85
    Gave up on Spartan
    Well I finally gave up on the spartan and ordered a miss Geico will get it Friday I was wondering if someone can give me a idea on the motor/prop selection I have a seeking 180 esc and will also be buying new batteries I am hoping to get it to run mid to upper 50's if possible
    Thanks
    Brian
    washed up factory racers edge driver.. past LHS owner now im back to the hobby I love
  • jac4412
    FE Addict
    • Jun 2010
    • 425
    This thread here mate:
    http://forums.offshoreelectrics.com/...ad.php?t=23950
    JP is reporting to be well into the 50s so there you go.. follow his mods
    JAC4412 RC
    • brian6989
      • 85
      Thanks for the info
      • JPriami
        N4FOX
        • 1675
        Yeah I gave up on that plastic thing too. I was going to get the geico or the Spartan. But choose the Spartan because it was a little longer and was supposed to be faster and better from all the hype I read before it was released. Got the Spartan and was disappointed with all it's aliments. Then seeing them fall apart left and right. I wanted to get away from the plastic toy and put my money back into fiberglass.
        • JPriami
          N4FOX
          • 1675
          I don't recommend following me 100%. I put a castle 1520 1600kv in my geico and am running 6S on a t-180. The motor barely fits in here. And honestly I feel that a slightly smaller motor like the 4074 leopards would do the same and get into the 50's no problem. And be less cost and easier fit. I was expecting to get mid to low 60's on this setup with the right prop. But so far ive been just at 60 with a best record of 59.8mph on a x642. For my setup that's about right on that prop. Currently I'm working on making the boat stay on the water near 60 mph and ride like I'd want it to. I'm getting closer. But I've only run this boat 4 times so far. Each time things get better.
          • brian6989
            • 85
            funny jPriami I have been following your posts on OSE while I have been waiting for the spartan you seem to have the best handle on the boat but after reading on the miss geico im glad the spartan is back ordered it seems to just have to many issues. I could not believe the video of the new spartan that the hull folded on that could have been a very expensive anchor.
            • brian6989
              • 85
              Thanks for the motor recomendation I will get one on order
              • JPriami
                N4FOX
                • 1675
                Yeah that video and that day is what changed my mind about making that plastic boat do near 60mph. I know it was a faulty hull and seam that might have caused it but still. Yuck.
                • brian6989
                  • 85
                  yes if it would have sank there was alot of money in electronics and batteries. Quick question i see they have a 4074 in a 1400kv and 1774kv version which would you think would work the best?
                  • JPriami
                    N4FOX
                    • 1675
                    I'd get the 1774 kv and run 5s. You should see 50's on that.
                    • brian6989
                      • 85
                      ok thanks ose is out of stock on the 1774 kv motor i will try a few other sites
                      • rcfreek
                        • 21
                        i just traded my new spartan for a used miss geico and happy with decision!!
                        • brian6989
                          • 85
                          sounds like a good choice with all the problems with the spartan
                          • Diesel6401
                            Memento Vivere
                            • 4204
                            That leopard 4074 1774kv is a beast of a motor. I hit 50.1mph on 4s in a Skunk cat that is almost identical to the MG in size. http://www.youtube.com/watch?v=5Kfe_...el_video_title
                            I toasted the esc on that run was only rated at 120amps and I pushed it waaaaay past 120 lol... stuck a swordfish 200 in there now. much better lol...
                            - Diesel's Youtube
                            - Diesel's Fleet
                              • 9488
                              Thanks
                              Brian
                              What about just running 5s on the stock motor?
                              it can take it and you have a S180 esc that will work great with it
                              you should see mid 50's with a 42x55 prop
