Hull Truing Results
  • wppracing
    • 109
    Hull Truing Results
    The biggest difference I noticed was the boat seemed to calm down while running at top speed. It looked more stable and turned flatter. As for speeds it was only
    .1-.3 mph difference.
    The water was flat as glass without any wind. It ran consistant high 39's with
    4s 40c batteries. Overall I am pleased with the end results.
    I have found the best set up with the boat and decided to installed the offset rudder bracket.
    I am going to compare the results later today.........
    Watercraft Performance & ATV
    wppracing.com
  • martin
    • 2869
    But it now has the potential to go faster with any upgrades you make ie bigger props, higher voltage, higher kv or bigger motor etc. Where as before it was starting to get out of shape at current speed so any faster speeds would have made things worse before mods. You say its not much faster but given that it corners better then lap times should be faster.
