Disconnecting the BEC
  • wppracing
    • 109
    Going to run an RX battery pack and want need to know which wire to remove. I have seen pictures of the blue or red wire unplugged.
    Watercraft Performance & ATV
    wppracing.com
  • RayR
    @SiestaKey.calm
    • Jun 2007
    • 1518
    Use a short servo extension and cut the middle (red) wire. Then no need to mess up your speedo plug.
    • wppracing
      • 109
      Where are you removing the red wire from ? The ESC ?
      A picture will help...
      wppracing.com
        • 7990
        He showed you a picture. You do not "remove" the red wire. Simply cut the red (middle) wire in the servo extension. Plug the modified servo extension between the ESC and the receiver. Voila.
        • H2OCamel
          FAST ELECTRIC EVERYTHING
          • Oct 2007
          • 484
          I use the same method it saves you when you sell your equipment!
          "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
          • wppracing
            • 109
            Got you now. I was stuck on the wires going to the motor
            wppracing.com
            • Diesel6401
              Memento Vivere
              • 4203
              I never cut my wires. I just pull it back out of the esc itself. Use a small jeweler flat head and lift the small locking tab and slide the red wire out..... no extensions no ruining a esc takes 5 second. I just place a small piece of heatshrink over the exposed wire.
              * I do like the extension idea though for quick switch between different setups.
              - Diesel's Youtube
              - Diesel's Fleet
              • wilsta67
                • Feb 2011
                • 203
                what does the bec do to start with and what advantages does it have by disconnecting it??
                • LiPo Power
                  DJI Drone Advanced Pilot
                  • May 2009
                  • 3186
                  BEC is power to your receiver.
                  By disconnecting the power to receiver and using external power source like stand alone battery you will save the esc from failing....
                  Canada
                  • Diesel6401
                    Memento Vivere
                    • 4203
                    Battery Eliminating Circuit..
                    Its in the esc, it takes the main battery voltage and reduces the voltage to provide power the rx and the servo. By removing/dis-abling it it ttakes added work/stress away from the esc increasing the life and durablilty of the esc. Most HV esc'c do not have bec. With added main battery voltage the harder the esc has to work to reduce the voltage for the servo and rx. Now this isn't the best answer or most technical by any means but you get the idea. I am sure Fluid may be able to provide a better idea on how this all works.
                    On most 2s-6s esc's such has the Hifei and Seaking (non-hv), I don't use the esc's bec on anything over 4s... That is just me, I also don't run those esc's past 5s. Once again just a me thing. I don't like pushing those to the limits. Not worth it to me...
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • Diesel6401
                      Memento Vivere
                      • 4203
                      Ooops, you posted while I was typing... lol
                      Didn't mean to repeat the similar answer.
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • wilsta67
                        • Feb 2011
                        • 203
                        so if you just remove the center wire what are the other 2 wires for?
                        and where do you connect the external battery power too ? can you connect to any other port on the receiver?
                        • Diesel6401
                          Memento Vivere
                          • 4203
                          Signal and ground...
                          Your rx should have a batt/bind or something similar slot That is where i run my rx pack. For the most part any slot will work though unless you have a telemetry rx.
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • wilsta67
                            • Feb 2011
                            • 203
                            ok so is a 6volt nimh hump pack battery ok for the power supply?
                            • pyroM!KE
                              • Jan 2011
                              • 375
                              Yup..Its what I use.. http://www.gshobby.com/index.php?mai...ducts_id=11131
