What is the best ESC to use with a 5s set up and still allow you to us 4s
Best ESC for 4s or 5s
its a toss-up question.......prob best is the turnegy 180 for the money but there are several brands that make the same esc ose sells them of one brand or another alsoMY RETIREMENT PLAN?????.....POWERBALL
Space....
Sometimes hard to fit t180s in certain hulls.
Whatever esc you get, dis-able the bec when running 5s....Attached FilesComment
Yea and 120s should be fine on 5s... I'm going to be running a 120 with the 1800kv outrunner and should be perfect on 5s. I'm going to get a 180 anyways but a 120 should be a ok.Comment
120 should be real nice on 5s with that outrunner. I am running a CC1800kv outrunner on 4s with the stock esc and a grim 42x55.Comment
Well ben (fightercat) just convinced me to screw it and go 6s on the 120... that'll really open it up... decrease the amps as wellComment
Increase in amps. More amp draw with increased RPM, spinning at over 40,000rpm there will be increase in amps with the system trying to maintain that RPM. If you do it. Prop low and conservative.
Me personally never a fan at running esc's at max voltage, but I play things safe.... There are people running those esc at max voltage with no issues, but some do have issues...Comment
Hmm... things to consider I guess. Heck maybe I'll try both out... doesn't matter anyways... USA warehouse is out of turnigys!Comment
alex you mean the grim? If I runn 5s the x642 should be pretty safe right? Or should I go smaller than the stock oneComment
i just put the turnergy 180 in a pursuit mono running 2 4 cells in parrell and no temp prob at all...used a 42 mm or cm what ever size we all use and it was great moving up to a m445 soon and test.....MY RETIREMENT PLAN?????.....POWERBALL
