What am I not doing correctly?
  • Havasufun
    • 17
    So...my maiden voyage was last night and early this morning...running 6s with 180seaking and stock motor...seems like its missing some power...do i need to disable the BEC on the 180esc or any other tweaks like that?
  • PDR447
    • Feb 2011
    • 92
    if it was your maiden how do you know it is missing power? you have nothing to compare it to...
    • jac4412
      FE Addict
      • Jun 2010
      • 425
      what prop are you using
      JAC4412 RC
      • dana
        Banned
        • Mar 2010
        • 3570
        I would disable the bec. Also check the timing, the seeking comes factory 15*degrees. I'm not sure what the stock motor requires
        • Havasufun
          • 17
          x642 prop...polished and balanced
          How do I go about disabling BEC? Do i have to run an rx pack if I disable...What does disabling do?
          Timing is 15
          Thanks
          • JackBlack26
            • May 2007
            • 903
            Pull the red wire from the ESC connector and heat shrink it back. Use ether an external BEC or a receiver pack. Disabling it puts less stress on internal circuitry, making the ESC run more consistent, specially on 6S.
            • Havasufun
              • 17
              I have a castle CC BEC rx battery eliminator...that will work?
              • bbosncali
                • 756
                Yep sure will
                miss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717
