Will a balanced M445 prop work ok with the stock set up? I run 7.4 40c and 50c lipos. and what timing should the esc be set at high or low ?
M445 balanced prop on stock set up
Prop will work fine. Set motor timing to high, get the rid of the deans connectors (if you haven't done so yet) and change out the 3.5mm bullets to 5.5mm bullets and you will have yourself a very nice running MG. -
Now, m445,stock motor, SK180 esc is awesome on 5s!!! Also a cf45 prop with the same setup is awesome 2..A cf45 on 5s will launch out of the water and ride a wheely setup just right..I love mine!! Only about 1 inch of the rudder and the prop only is in the water..Comment
On 4 cell not 5 cell...Dont do it on 5s..Ask me why..
He posted he was running 7.4's so he's safe on 4s.... Yes to the OP that prop on 5s stock is no no.... Pyro has the charcoaled souvenir to prove it lol...Comment
you'll be saving yourself alot of money in the end.. for about $20 in connectore vs $60 motor $70 esc $30-$75 x2 batteries = alot more than $20
start with something small like an x642 if you just can't wait but the bigger the prop the bigger the load and deans are only rated at 60amps on a good daymiss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717Comment
ec5 connectors are another good choice and most hobby shops carry them. i use those on my esc and batteries and 5.5mm on my motormiss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717Comment
Switching over is gonna add reliability to the setup. One of the best quickest and cheapest upgrade you can make to any RTR boat not just the MG is switching to bigger connectors and dumping the deans.Comment
