Stick with the 4074 2200kv on 4s, Only mentioned 6s because it was raised in thread. Martin.
the OP said he wanted to use 6s, that is why i said something about 6s.
I think you will be happy with the 4074 2000 kv on 4s. I have a ul1 2030 kv with an m445 and wouldn't want to go much faster. I would think the leopard would be a more powerful and efficient motor then mine, so you could prop up i'd imagine.
I didn't catch the 3000 mah batts. You will be getting 2 min of run time give or take.
With those batts i'd stay with the stock motor on 6 s with the t 180. 1500 x 22.2 = 33300. With an x437/3 or a x440/3 you will be flyin. As i said before i dont know squat about 6s set ups though so i could be way off on prop size, those should be relatively conservative though.
I think the 4082 might be a little much for MG as well. I have a 3656 size can and she is a hand full on that.
you guys are awesome and this info has helped a ton...off to work and then home to order motor...gonna go with the 2200kv on 5000mah 4S...
I have this motor in my mg with a 150a esc and only running a x642 offset rudder and on 2s 40c 5000mah lipos and it keeps up if not a tad faster than my buddies 6s spartan. I am gonna push the limit though and try it on 5s against everyones advice. I did however buy a backup seaking 180a esc for if and when my esc goes. If you don't want to throw away your money definetly stick to 4s or buy a lower kv motor like a 1500kv or at most the 1774kv jmo
miss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717
Would the 3660SL 3060KV motor be a good option if it were run on 2s or 3s? Also, what is the main difference in using a low Kv motor on 4s comp with a high Kv motor in 2s?
High kv=more speed, less "pushing" power. You should really stay away from kv that high in this boat... It's going to be working very hard to get speed. I'd say its a 4s minimum boat.
so ur saying I should stay with 2 2S packs??? or will a 2000kv motor with the 180 do great with 2 3S? thanks
and can I expect any gain from just adding the 180 and leaving the stock motor
I ran a tacon 4074 2000kv on 6s with an octura x642 and it screamed hit my highest speed of 63.4mph but my run times were about 3mins with a set of gens ace 5300mah 30c temps were only105 it was fun but not long enough run times. The leopard 2000kv is rated at 25vlts so 5s shouldn't be a problem but that's jmo. I love high rpms but that's also living on the dangerous side and pretty muc asking for something to break. But atleast ill have fun doing it
I got a dumb question, but I noticed the lepord motors don't have cooling jackets, Do they need them? or do I just use the stock MG cooling jacket off the stock motor?
Thanks
I also want to modify the boat set up to get more speed but don't want to spend too much money. I want to buy the seaking 180A esc and a leopard motor 4074 2150 kv or 2200 kv. Will it be possible to run 5S with that setup ? Can I keep the stock motor mount or do I need to buy a new one ? What are the matching cooling cans for leopard motor ? Thanks for your help.
No don't run 5s on either of those motors. Stick to 4s with them.
if u are tight on cash use the t 180 and the stock motor on 4s .....prop it with a m445......5.5 bullet conectors all around and u will get into the low to mid 40's......u will have to dremal the cornor of the strut bracket but thats about 5 min work.......
A miss Geico with a 4082 a t180 using the internal bec 6s 5000ma 40c and the pro boat radio with a 42 x 55 Grim Racer prop has pulled 50 runs or so with no problems other than blowing the blades off the original props,and eating a strut and flex shaft. To get rid of the bounce i cut the original strut slot a little lower with a dremel and raised the prop. I also glued a big flat catfish weight to the nose and put some fiberglass to make the front wing stiffer. The Boat is a bullet just stop pulling the trigger 20 feet from shore or your gonna make a hole in whatever you hit.
Nice.... Those leopards do run good but I love my cc 1518 I run it on 6s without any problems I'm over the 33000 rpm mark but just under 40000 and run consistent 60's I know I'd be safer running 5s but when compared to 1600kv motors on 6s it's really not a whole lot more. I'll keep rolling the dice for now
