lipos in saltwater
  • scrpio17
    • Jan 2011
    • 13
    lipos in saltwater
    running boat today everything great till boat went over running into wind hatch came off and clear lid leaked even with tape salt water got in and cleaned everything and sprayed down everything works fine ran after cleaning thank god for corrosion x only problem is the two batteries that were running seem good except three wire connector for charging red wire corroded away is there any where to get replacement pins or do you think batteries are junk now.
    Thanks, David
  • Blockhart
    • Jun 2011
    • 39
    depends on the batt but should still work with replacement wires. I run in salt water all most all the time and sometimes it does get wet inside. hose it off, flush it out, blow it dry with compressed air and I spray everything with silicone. no problems yet.
    Miss Geico?
