150a esc 4074 leopard 2200 on 5s/6s
  • bbosncali
    • 756
    dont know a whole lot about these motors except they run pretty good and fast. does anyone with experience with these or similar setup run 5s and or 6s???? also what would be a good prop to do so with?
    miss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717
  • bbosncali
    • 756
    This is what I found but would still like to here from people that have tried it
      • 8012
      Don't need to try it. A 2200 Kv motor is a no-no on 6S and really is too much for 5S. That is a hot 4S motor as it is.
      You'll find that they burn up ESCs pretty good and fast on 6S.
      Why do you want to run 5S or 6S? What hull is it going into?
      • ron1950
        • 3024
        agree with fluid 4 cel is plenty with this motor
        • JackBlack26
          • May 2007
          • 905
          I believe Blackcat has run a 2200 on 6S. He always mentioned being a fan of high RPMs. Though I don't think he ran it in a MG.
          If you don't try this before me, I'll try it in my Genesis in a few weeks when I head back out to the water. You never know if it works till you try it! I'll be spinning an x438 though just to keep amp draw under check.
          • bbosncali
            • 756
            How do you check amp draw? And using a 438 is that going to be on 5s or 6s?
            • pyroM!KE
              • Jan 2011
              • 375
              You need a data logger to check amp draws voltage draws ect...
                • 8012
                It has been tried many times, and the result is almost never good. Go ahead, re-invent the wheel, it's your money.
                • pyroM!KE
                  • Jan 2011
                  • 375
                  I agree..If you want to see some fireworks wait untill June..Then you can buy some cheaper fireworks at the fireworks stands..
                  Im just saying..If you want to push a motor to the limits on 6s reliably then get a 1800kv motor..
                  • bbosncali
                    • 756
                    well this is what i got from an email straight from leopard hobby tech support.
                    Hi I purchased a 4074 2200 kv motor wanting to know if it can handle 5cell and 6cell lipo I use this motor in a 30inch boat
                    Dear Sir,
                    Thanks for your email and your trusting on our Leopard products.
                    For your question,LBP4074/2200KV the Max Voltage is 23V,and you could handle 5 cells lipo.Kindly know it.
                    Any questions,just don't hesitate to email to us.
                    Leopard Power Model CO.,LTD
                    ----- 原邮件内容 ----
                    so i guess ill be the guinee pig
                    • electric
                      • May 2008
                      • 1744
                      Dear Sir,
                      ----- 原邮件内容 ----
                      sooo..good luck. You never know it may work. Technology does sometime change things. Odds are good though you might find esc's going up in smoke or drive train issues because of the higher rpm's. I went down the path you are going a few years ago and it was at least entertaining. After some explosions and multiple drive train issues I realized for dependability and fun you need to keep the rpm's in the reasonable catagory. Of course, if you want to do just top end staight line speed and you enjoy experimenting with different gear, and you have the budget, then enjoy... you will learn a lot in the process...While it was expensive for me, I did enjoy it for the most part.
                      • ron1950
                        • 3024
                        so kindly know it lol
                        • bbosncali
                          • 756
                          Will this work for a watt amp meter? It does measure amp draw just want to be sure
                          • lectriglide
                            • 538
                            http://www.hobbypartz.com/88e-aepm30...att-meter.html
                            It's only rated for 100 amps - no go.
                            • Diesel6401
                              Memento Vivere
                              • 4204
                              Dear Sir,
                              ----- 原邮件内容 ----
                              The voltage is NOT the issue. It's the rpms and amp loads. That motor would prob work in a car just fine on 5s or 6s but cars have gearing and don't pull nearly as many amps as boats do. Heres the truth the question isn't IF it will blow something the question is WHEN.
                              It's gonna blow something, it's just a matter of time!
                              - Diesel's Youtube
                              - Diesel's Fleet
