11.1V 25C 5300MA Lipo Battery
  • wppracing
    • 109
    I currently us a 7.4v 25c 5300ma Lipo Battery and like the way it runs.
    Will I gain any performance/speed/rpms by using the 11.1V 25C 5300MA Lipo Battery?
    Thanks for your help...........
    Watercraft Performance & ATV
    wppracing.com
  • Brushless01
    • Apr 2010
    • 487
    I presue you use 2 of the 2s lipo batterys for 4s? No you can not use 2 11.1v 3s lipo batterys but you can run one 2s and one 3s for 5s if you disconnect the B.E.C.
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
    • Boomer
      • 285
      I am running 6s in my MG (2 x 3s 5000 40c) Stock motor, x642 blueprinted prop, 120A ESC. Works fine, no issues.
      I had to upgrade the stock ESC as it didn't like that much juice. It opted out. (smoked it)
      Before I smoked the stock ESC, I got about 10 passes over two days. Hauled butt!!
      With the new ESC I've had no issues to date. 5s be fine, 6s are faster.
      Food for thought, not a recommendation.
      Boomer
      • wppracing
        • 109
        I decided to stay with the 4s for a while. Picked up some 7.4v 35c 5800mah lipos for a good price. I am going to see how they work compared to the 25c batteries. Also going to test the stock prop and the proboat stainless prop
        wppracing.com
        • wppracing
          • 109
          Went out and tested the batteries. The water conditions were not the best for testing, strong wind coming from the mountains. The results are listed below
          7.4v 25c 5300mah Lipo with stock prop 31.4
          7.4v 25c 5300mah Lipo with proboat S/S prop 30.9
          7.4v 35c 5800mah lipo with stock prop 32.9
          7.4v 35c 5800mah lipo with proboat S/S prop 31.5
          wppracing.com
          • jac4412
            FE Addict
            • Jun 2010
            • 425
            wpp, with some better props you'll be able to run 35-40 mph consistently.
            I've been debating whether to keep my MG stock or not since it runs so beautifully but now that summer is near, I think I'm going to throw in a T180 on 5s with an 1800kv outrunner.
            I've tried the x642, m445, and proboat 3 blade /55 props
            JAC4412 RC
            • wppracing
              • 109
              I have a X642 and Grimracer prop coming, balanced a polished
              wppracing.com
              • wppracing
                • 109
                I tried a set of 7.4v 40c 5000mah lipos and a Balanced and sharpened X642 and ran 37.8 with wind and rough water. I hope to test again monday if the wind stops....
                wppracing.com
                • LiPo Power
                  DJI Drone Advanced Pilot
                  • May 2009
                  • 3186
                  X642 is wicked!!! Try M445 next...
                  Canada
                  • wppracing
                    • 109
                    I am trying to find one now.....
                    wppracing.com
                    • wppracing
                      • 109
                      Went out today and ran 38.1 mph with the X642 prop. I also had a GrimRacer 42/55 that I balanced and it ran 37.3 mph.
                      wppracing.com
