Does anyone know if you can run a 2s 5000mah and a 3s 5000mah battery together to make 5s? I just purchased a mg and keep reading that a lot of people run 5s lipos but before I purchase my batteries I want to know what will work for best results without upgrading my esc. I'm looking to try and atleast keep up with my friends spartan. Thanks for your help
can you run a 2s and 3s together????
Yes you can as long as there the same C rating.Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx. -
Be sure to disable the bec and run a external rx pack or your stock esc will let the smoke out..Also..I wouldnt run any prop bigger than a 42mm..I ran a m445 on my stock esc on 5s with the stock motor and the esc went up in smoke...I would run a x642 on 5s or the stock prop..Comment
Same C rating AND same mah rating. It also helps if the packs are around the same age/number of cycles and the same brand! Failing to do so will lead to bad things!Does anyone know if you can run a 2s 5000mah and a 3s 5000mah battery together to make 5s? I just purchased a mg and keep reading that a lot of people run 5s lipos but before I purchase my batteries I want to know what will work for best results without upgrading my esc. I'm looking to try and atleast keep up with my friends spartan. Thanks for your help
Like mentioned stay away from that Spartan, you don't want you or your boat anywhere near that thing when it goes it in smoke....Comment
Just cracking jokes, all in good fun, hopefully he doesn't take offense. I ran 46mph on a stock mg on 5s with a x642... If he is running a stock spartan on 6s your mg on 5s should get close.
And then I'll sell my stock stuff and get the t180 and a castle and hit over 60 mph...47.1 is my best so far and stable too. No offense taken I make jokes too. My speed control blew the 1st day I powered it on....traxxas customer service is the BEST, that's why I stick with them. I can't wait to drive miss geico though. My boat on 4 s is pretty slow though. Just over 30 mph. I want mid 50'sGenesis (Bosncali Geico Beater) Leopard 4082 1500KV
(63.7 MPH) Traxxas Spartan (same setup)Comment
Ooooohhhhh.... well esc is on the way offset prop on the way x642 prop on the way all I need is 1 3s and ill be right next to you buddy..... you and your plastic tonka toy lolmiss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717Comment
