Has anyone installed Redline pushrod seals
  • Boomer
    • 285
    Hey Guys,
    Just wondering if anyone out there as installed Redline's pushrods seals for the rudder servo boot or bellows. I have been trying to come up with a way to install a new rubber boot or bellows without having to hire an elf to get inside the hull to glue it to the inside of the hull. You can see them at http://redlinemotors.us/#/radio-equip/4526084178
    They are the 8th item from the top of the page.
    These look like they'd do a nice job.
    Boomer
  • Chilli
    • Jan 2008
    • 3070
    I use them on my JAE and on the radio box in my gas boat. They do a nice job as long as you use the Aeromarine seals as Patrick stated. They take up allot of room so if you have a rudder mount that has four mounting bolts and a hole in the middle for the pushrod to go through, there's a good chance you wont have enough room for the seal mount. In this case, use a short piece of brass tube and slip a pushrod seal over it. Hold it with a little CA or a zip tie.
    Mike Chirillo
    www.capitolrcmodelboats.com
    • Boomer
      • 285
      Thank you. Can you tell me the O.D. of the male end of metal fitting? I can't find any dimensions on these things.
      Thank you
      • Chilli
        • Jan 2008
        • 3070
        The widest part at the tip where the seal slips over is about 7/16" Once pulled over that tip, the seal sits on an area about 5/16" in diameter.
        Mike Chirillo
        • kjohnsiii
          • Oct 2010
          • 116
          These are kinda neat I might have to get a set.
          • Boomer
            • 285
            I attached a photo of one of the boats I am hoping to install these on. You can see the factory pushrod rubber boot. I will measure the hole to see if these guys will fit.
            Thank you
            Boomer
            • Chuck E Cheese
              • May 2008
              • 1684
              i use nothing but redline seals, they are by far the nicest set-up i have found..
              see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
              • HOTWATER
                • Nov 2008
                • 2323
                I've been using them on my builds as well...nice and neat....works perfect with Speedmaster rudder mounts...
                "Will race for cookies!"
                IMPBA D12
                My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
