Also here is a pic of th elinkage hooked up and working. Has very nice and even motion, i didnt cut the rod yet cause it may not work (Stupid Snow), and its hard to see in the pic, but there is only a slight downward angle of the linkage, it pulls back on the boot, but doesnt seem to work the servo..... Time will tell. Hurry up April!!!!
New/different way for offset rudder
Looks good !!! Did you lay the oak flush against the rear ? or did you have to cut out the ridge on the inside to make it sit flush?? You know the seam with the little piece of wood on it? The altered stock peices look good . Almost makes me want to order another set and use them instead of using the UL 1 rudder mount bracket. NICE JOB !!Comment
That was the idea, to keep all the hardware looking original! we have extra Proboat parts coming so the strut bracket will be back to normal just shortened up to the strut, so it will take any prop size no matter where the strut is adjusted to.
Hobie, I will check tonight when the extra parts are expected to arrive.. Hurry up April thaw!!!There is no replacement for displacement, I guess I just have to Buzz it higher!Comment
