Rudder to Strutter conversion
  • igottalongone
    Banned
    • 204
    A quick easy mod...
  • Darin Jordan
    • 8335
    That's really nicely done. Same idea I did this weekend. Great minds, and all that...
    One thing I would recommend, however, is that you allow the standoffs to NOT pass through the strut bracket, and instead, sandwich the spacers (I'd make them out of metal) between the two halves of the strut bracket. This turns it into an "I-Beam" arrangement, making the bracket much stiffer. Might not work as well with the thin standoffs you used, due to their narrow mounting base, but with the larger ones I used, it's rock solid, and the strut brackets don't flex at all.
    Either way, it's a good upgrade.
    Darin E. Jordan - Renton, WA
    • igottalongone
      Banned
      • 204
      @Darin
      We will have to agree to disagree on this one Darin. I preffer this method over the "butt joint" attachment. I've been running this mod since I got the boat, it's worked perfectly and is rock solid... It's just a copy of an Octura Strutter...
      C-Ya on the Lake...
      Ron
      • Darin Jordan
        • 8335
        Originally posted by igottalongone
        @Darin
        C-Ya on the Lake...
        Ron
        Just a recommendation... yours is just relying on one side of the bracket for torsional rigidity, mine uses both brackets and turns it into an I-Beam. Either will work.
        • igottalongone
          Banned
          • 204
          Actually with my union, the more load, the stronger it gets...
          Both ways are plenty strong, not counting Turtles and Driftwood...
          • jac4412
            FE Addict
            • Jun 2010
            • 425
            Darin, igot, how far over did you move your rudder? 1, 2 inch?
            JAC4412 RC
            • ron1950
              • 3024
              ok darin .now that u have solved the bounce in the mg lets get on with the racing duck prep thread....lol
              • 7500RPM
                • Jan 2008
                • 110
                Here are some pictures of the rudder mod I did last week.
                Well, I took my Cat out on Sunday and NO MORE BOUNCING! all gone! I offset the rudder to the right hand side using Octura offset rudder mounts ( two of them, one for each bolt ) moved the rudder arm to the other side and everything fit Great! Cut a piece of plastic to take up the thickness of the original rudder mount so when you tighten the screws for the Octura standoffs you do not collapse the strut brackets. The only thing I had to do was to slot the holes for the rudder arm. The cat runs much better! faster in the corners and also in the straights! You have to do this! It is worth it for the extra speed you get!
                There is no replacement for displacement, I guess I just have to Buzz it higher!
                • Darin Jordan
                  • 8335
                  My Spacers are 1.625" long... I also moved the rudder forward a bit, to get the leading edge up closer to being inline with the drive dog, and out of the thrust cone of larger props, and also allows the stock steering linkage to be utilized.
                  • ron1950
                    • 3024
                    i like the octura ready to use offset spacers but cant find any on the net anywhere? anyone know wher i can find a couple of em? thanks
                    • Darin Jordan
                      • 8335
                      Can you elaborate on how long those Octura Spacers are??
                      • Steven Vaccaro
                        • 8723
                        I have them, but for some reason they disappeared off the site. Probably because they never sold. I have to look for them tonight.
                        • Darin Jordan
                          • 8335
                          That would be cool... Let us know.
                          Also, I was looking at both methods for doing this conversion. It might be advisable, either method, to use a brass, or otherwise "sheerable" fastener on the rudder side, lower mount. Should hold just as strong, but will let go and save the transom in the event of a turtle or other object.
                          • ron1950
                            • 3024
                            hey steve ill take 2 octurea spacers if u can find em.....pm me a price or whatever if u find em thanks
                            • tman52804
                              • Apr 2009
                              • 101
                              I like those octura spacers, they look sweet.
                              I can't believe how high everyone's strut is. Mine is flush and runs great. When I had mine that high it did a dance.
