what about putting some power in MG
  • Steven Vaccaro
    • 8721
    Oh no!
    NA, I'm not sad. I pushed it hard and it pushed back. I will strengthen the next hatch and try again.
    • Darin Jordan
      • 8335
      Originally posted by scoota
      No the speed was a little less with the m445 , i was gpsing 51 mph , the prather has a lot more pitch , i ran a M447 it was faster but didnt have the gps on board ,going to try a M645 next & see what speeds i get ....
      You guys are kind of killing me here... New motors?? The stock motor will handle WAY more prop than this... The 645 only has 2.835" of pitch... The 447 only 2.598"... I ran a Prather 230 on mine and the motor temps after 6-laps on an offshore course were 117-degrees... that's 2.992" pitch... and I feel it's only scratching the surface for a race setup... Diameter might end up being an issue, but if one knows how to pitch up props, I'd start bending on an X645 or similar and see what that will do pitched up to 3+" of pitch...
      Of course, if you are just bolting on props, then a new motor might be better, because you can get the RPMs up, which will make up for the lack of pitch in the prop...
      Darin E. Jordan - Renton, WA
      • airman66285
        • Aug 2009
        • 244
        Darin,
        I want more speed without jumping up to 5s - all of my packs are 4s and I am happy with that. I agree with you - the PB 1500Kv motor in the MG can definitely take more prop than my Octura x642 but I want my speed to go from 38mph (current stock setup) to high 40's or even low 50's with a 2200Kv Leopard 4074 and new Swordfish 200 amp LV ESC (once Steve gets them in). My MG should cruise withg that set up - what do you think?
        • Darin Jordan
          • 8335
          Originally posted by airman66285
          Darin,
          I think... actually I KNOW, that the stock motor setup will do high-40's in race trim with the right prop... But, agree, that it will be easier to achieve with a bigger motor setup. Just a lot more expensive.
          • Steven Vaccaro
            • 8721
            Breaking what works well is part of the fun! I have guys ordering motors with NEW boats and changing them before they are even wet once.
            • Darin Jordan
              • 8335
              I LIKE IT!!
              It's all good... If I wasn't having to work within the framework of a set of power parameters, I'd be doing the same thing... I have a 1521 1.5D that is just sitting here!
              • Chuck E Cheese
                • May 2008
                • 1684
                go darin.... well put. what good is a spec boat if it isnt "spec"
                i am the one that started this thread and am now looking at it in a new light.... it should have been titled "what about getting some speed from the stock MG"
                see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
                • airman66285
                  • Aug 2009
                  • 244
                  #23
                  If I were to keep the MG as PB as possible, what do you think about putting a Feigao 540 12L (2,159Kv) in and keeping the existing ESC? Of course, I would keep the x642 as well... Will the stock ESC handle that motor?
                  • Darin Jordan
                    • 8335
                    #24
                    It IS just a 45A ESC, though we all know it will handle more. I'm not going to suggest one way or the other. It "might" is about as far as I'll go, mostly because I don't know for sure.
                    Mine in my P-Limited OPC Tunnel lasted for over a season of races pulling an average of 60+Amps, with long stretches (through the turns) of nearly 100A... Then, one day, it just didn't anymore...
                    • airman66285
                      • Aug 2009
                      • 244
                      #25
                      That's exactly what I was thinking - I will just wait for the 4074's to get back in stock and order one then with the new Swordfish ESC. I don't want to run the risk of nuking anything and damaging my beautiful MG hull! I can't tell you how much fun I have driving that thing! Thanks for the input.
                      • scoota
                        FE DOWN UNDER
                        • Dec 2008
                        • 409
                        #26
                        Why are we killing you ? each to there own , yes i didnt even run the stock esc & motor , i have been thru all this with the BJ 26 & i know the stock set up will handle more prop ! the 1515 & 240 esc gives me more room to run different props with out pushing the motor & esc , after running a prather 225 , for 4 mins my temps were half of yours & thats what i want with my set ups ...
                        UL1- 1515 castle/neu / 240 swordfish
                        SV27- with UL1 running gear
                        33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
                        • Darin Jordan
                          • 8335
                          #27
                          You have to read the rest of the thought:
                          The bottom line for me is that it doesn't take much work to bolt in a motor and ESC and make a boat go 50mph... Anyone with $$$ or enough credit can do it.
                          It's a lot more setup and skill to get it there with the stock power system... THAT is where the thrill comes for many of us, and also how you learn about props, sharp hulls, etc.
                          But as you said... to each their own. It's all good! I'm just happy you all are enjoying the hull!
                          Can't wait to see what we come out with next...
                          • ray schrauwen
                            • 9471
                            #28
                            duplicate
                            Nortavlag Bulc
                            • Cottageboater
                              • May 2008
                              • 779
                              #29
                              I had the opportunity to run my MG this weekend. Due to a faulty stock ESC, I ran the only set-up I had available which was a 12XL, 150 Etti, x645 on 6s. All I can say is wow. With very little set-up, i got 53.6 on the gps. The boat was fast, stable, and most of all fun. There was a 10-15 mph wind and chop all day, but the boat ran great. All I can say is congratulations to Proboat. I can only hope their next boat is a revised version of the Miss Elam that accomidates larger lipos, has the waterproof lid, and adjustable 3/16 hardware...and since it is about to get cold here, is ready for the start of next season. Great Job.
                              • ray schrauwen
                                • 9471
                                #30
                                Nice setup thanks for the input!!!
                                Nortavlag Bulc
