6s ??
  • Brushless01
    • Apr 2010
    • 487
    6s ??
    Hi could this boat be ran on 6s with a turning 80 amp HV esc ??
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
    • 7990
    If you keep the prop size down probably. It is not difficult to prop these motors to 90-100 amps on 4S, so be certain to prop down on 6S. 33,000 rpm is a lot of revs - I'm not certain why you'd want to do this, yet limit yourself to just 80 amps.
    • slyman
      • Jan 2009
      • 126
      Go for it. I run the stock BJ26 ESC & Motor in my UL-1 on 6S without any problems.
      • Rumdog
        • 6453
        Make sure to remove the red wire from the esc harness and run a rx pack. SMALL prop, like Fluid said. 5s should be more than enough for big speed though, and the right prop on 4s will make it move!
        • Diesel6401
          Memento Vivere
          • 4203
          46mph on 5s with a x642. Click the MG name in my signature for video of 4s & 5s. The motor can handle 6s voltage but the esc is not rated for 6s. Disconnect the bec like rum said. I use a 2000mah nimh rx pack.
          - Diesel's Youtube
          - Diesel's Fleet
          • Brushless01
            • Apr 2010
            • 487
            Could i disconnect the factory bec then solder in a castle one ?? How about a T180 esc instead ??
            • Diesel6401
              Memento Vivere
              • 4203
              I'm sure you could, but it will still be taking away power from the batteries. A t180 will work, a t80hv would work as well.
              - Diesel's Youtube
              - Diesel's Fleet
              • Steven Vaccaro
                • 8724
                I've been playing with my Geico for 2 days now. Its been running great. I'm not sure why people always want to over power their boats. I understand its a rush, but crashing at 40 and crashing at 60mph will yield much different results.
                My opinion is that if you want to have a rush or sorts, find someone with another geico and race. It will get the blood flowing.
                • Doby
                  KANADA RULES!
                  • 7277
                  Those that crash at 60 will be the ones bad-mouthing ProBoat for their lack of "Quality".
                  Grand River Marine Modellers
                  • Diesel6401
                    Memento Vivere
                    • 4203
                    I am very happy with the stock system in this boat on both 4s and 5s.
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • Darin Jordan
                      • 8332
                      To add too that... put out some buoys, and try to race on a course against someone else, holding lane one, dicing for the lead, for a mile or so. You might find that speed is all relative, and frankly, not the important part of the equation.
                      Steven... LOVE the new smilies!!
                      Darin E. Jordan - Renton, WA
                      • Steven Vaccaro
                        • 8724
                        Or burn up a esc.
                        • ron1950
                          • 3024
                          bounce
                          this guy seems to have found out how to stop the bounce and stilll go fast...
                          • jac4412
                            FE Addict
                            • Jun 2010
                            • 425
                            Yeah its running real smooth in the video
                            JAC4412 RC
                            • blackcat26
                              High Speed Junkie
                              • Sep 2009
                              • 1598
                              It does sound much better. Hard to tell 100% if it's gone with the background music. His description says he made longer batt. trays and brought the batts back a little......
                              FE BOATING: Less like a hobby and more like an addiction!
