Update and repeat form "strut rudder conversion"
More testing today and feel like Im getting somewhere. I started w/ the strut neutral and about 1/2 below the bottom of the hull. Batteries were half inch off the back of the trays. Bounce bounce bonce. I left the batteries alone for all of the adjustment. I angled the strut down slightly, then up slightly.. bounce bounce bounce. I tried lowering the strut. And again went thru 2 different up angles and 2 different down, including neutral.. bounce bounce bounce. I then started slowly adjusting it higher and higher, again using all angles and it slooooowly began showing improvement. It seemed a slight positive and higher depth is what it wanted. I moved it up to clear by thousandths of the bracket and had the best run yet. However after bringing it in, she slipped a tad and the prop contacted the bracket just slightly. I re-set it, tweaked the prop and then I tried messing w/ the rudder angle. I tucked it forward, it seems to have brought the bow down in the straights, BUT, the bounce was almost gone. I pulled it back out just a bit and runing w/ the wind in about a 1/4" to 1/2" chop, light breeze, no bounce at all. Running into the wind she bounces minimally. My strut is angle slightly up and as high as it can go before the prop (642) contacts the strut bracket. Darin had mentioned that some of the struts were mounted at the bottom and caused issues w/ prop clearance. I feel I need to go a smidgen higher, but, My strut is one that is mounted at the bottom of the transom. Im going to remove part of the tail of the bracket to see if I can get enough clearance and if it is in fact my resolution before I go removing the bracket and drilling new holes in my pretty boat. I actually feel like Im getting somewhere.
Most importantly as Darin said, the strut brackets on these boats apperently arent all mounted in the same location. I feel its important in the "helping of others" that we get back to refering to the strut angle as compared to the bottom of the boat while sitting on a flat surface and not the "top of the strut" like we somehow got into on this.
Darin, thanks for your help in this set up. I was told by a reputable racer about pulling the rudder out.... DEFINITLEY not the thing to do. Since it was cornering wonderfully to begin with, I never thought to try tucking it in.... Thanks!
Since this is more about bouncing and not the offset, my following test result will only be in this forum.
