Miss Geico Race Prep
This is a sticky topic.
  • hobie
    • 98
    #76
    Sweet! Thanks, i know what I'm doing tomorrow.
    i will let you know how i make out with it
    • blackcat26
      High Speed Junkie
      • Sep 2009
      • 1598
      #77
      Hey Darin, I was thinking about what you were saying about the rudder bracket may be causing lift from prop wash today and you may be right. I noticed that I can still get the "wa wa" at certain speeds (Around 30 or so) A little faster and it goes away. Could it be going away because of the increased wind speed from going 50 instead of mid thirties, shortening the roostertail? Also when I get off throttle from top speed the rear kinda acts strange. Maybe this is why it likes a little more depth of strut???
      FE BOATING: Less like a hobby and more like an addiction!
      • stringfly
        • 88
        #78
        Bec
        If when running 5s you need to disconnect the bec (disable) then do you use a onboard receiver pack ????
        Stringfly <>++++
        • hobie
          • 98
          #79
          Stringfly <>++++
          Yes, onboard reciever pack.
          I am using a 850mah life pack. The 6.6 volt lipos. Works awesome. Even on 4s it seems to help it out a bit
          • ray schrauwen
            • 9438
            #80
            Darin, how long is the hardware from transom to end of rudder? please, thanks!
            Nortavlag Bulc
            • hobie
              • 98
              #81
              Hey, just grabbed my tape measure... If my eyes are correct, it looks like 4 1/8" or 103mm.
              • ron1950
                • 3024
                #82
                Just got my 642 back from chuck. Wow u can cut a stake with it. Nice Also. What is the bec you are talking about? Is everyone using the 642 or the 445 with 4 cell?
                • ray schrauwen
                  • 9438
                  #83
                  Thanks buddy!
                  I just checked the inline hardware I have and its a 1/4" shorter... Should be O.k. I hope if not I can just buy the PB hardware after.
                  Great hull only! I'f I didn't have everything already would have enjoyed the RTR also, really nicely built.
                  Nortavlag Bulc
                  • Darin Jordan
                    • 8332
                    #84
                    Thanks buddy!
                    Ray... can you post a picture of your inline hardware?
                    I'm going to try offsetting the rudder on mine to see what the effect is. I think it will scrub less speeds in the turns, and my eliminate the "bouncing" that people are seeing, but I have to try it to see.
                    Darin E. Jordan - Renton, WA
                    • ray schrauwen
                      • 9438
                      #85
                      It's the hor inline hardware just drilled out and Lead teflon pressed in...
                      I had to drill the bracket holes out a bit with a 9/64 drill but, it looks clean, not butchered. I'll post some ppictures when I install more stuff...
                      I hear you on the inline hardware, always room for improvements, mods...
                      Nortavlag Bulc
                      • Darin Jordan
                        • 8332
                        #86
                        I think I have a way figured out to accomplish the rudder offset using all the stock pieces, with minimal mods... my favorite kind of mods!
                        • Diesel6401
                          Memento Vivere
                          • 4203
                          #87
                          Yea I have used a x642 on it with 4 cell. Ran very nice, my video shows both 4s and 5s runs on a x642. The bec is the red wire on the lead that plugs into the rx and supplied the rx with power. Simply pull it out and run a seperate pack.
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • ray schrauwen
                            • 9438
                            #88
                            I was thinking about that too Darin. Maybe some stand off's ??
                            Nortavlag Bulc
                            • Jeff Wohlt
                              • Jan 2008
                              • 2716
                              #89
                              Odd.... my HOR cat does not bounce with inline rudder. Not sure that is really an issue but every boat is diiferent.
                              www.rcraceboat.com
                              jwohlt5362@yahoo.com
                              • ray schrauwen
                                • 9438
                                #90
                                Could be a ratio of hull length vs rudder length..., the rudder on Miss G is the same size as HOR but, it's hull is shorter. I don't know this theory, I'm just a suposin'
                                Nortavlag Bulc
